Results 1 to 10 of 10
23rd Jan 2017, 04:34 PM #1Golden Member
- Nov 2005
- adelaide
- 597
SOUTH AUSTRALIA horizontal milling machine
a working horizontal milling machine not sure of its make but it appears to be either a pallas or victoria or a cross between both
comes with 2 hp 3 phase electric motor set up to run from vfd.
a very heavy duty vise but the jaws dont quite touch but just use a spacer to take gap if using very thin work
new flat belt
no drive belt between motor and speed change wheel needs about 60 inch v belt
has an add on coolant pump( looks like a washing machinE pump
has a universal table ( so it swivels) and i think table is 38 inches
NOW the but bit it weighs a bit over a ton i dismanteled it into 3 parts to get it home before i stripped and cleaned it all down
currently sitting on a pallet jack
x and y power feed
i would hate to see this go to scrap
$300
i can help load onto low trailer in smaller sections but with an engine crane
location Craigmore
click on photo twice to turn it round the right way
johnLast edited by tanii51; 24th Jan 2017 at 04:27 PM. Reason: wrong table size
24th Jan 2017, 08:23 AM #2Senior Member
- Dec 2009
- 327
Sorry we aren't closer.
I'm keen to get an old mill.
A.'Waratah' spring hammer by Hands & Scott c.1911- 20, 'Duffy, Todd & Williams' spring hammer c.1920, Premo lathe- 1953, Premo filing machine.
6th Feb 2018, 02:40 PM #3Member
- Sep 2016
- Canberra
- 89
Andrew, I feel your pain! I have seen two lovely old mills for sale in SA. Pitty it's so far hey!
6th Feb 2018, 03:53 PM #4Golden Member
- Nov 2005
- adelaide
- 597
its still here for sale any takers ??
6th Feb 2018, 05:27 PM #5Most Valued Member
Hi John I'm interested but am part way through a shed extension, which will give me extra room, but will be about 6-8 weeks before I can do anything about it.
What height is it and are there any cutters with it? Do you have a VFD that you'd sell to go with it??
6th Feb 2018, 06:34 PM #6Golden Member
- Nov 2005
- adelaide
- 597
KRYN it is about 64 inches high to top of motor but this will go lower by shortening the flat belt which needs doing ( its a new belt)
no vfd i use the one i have on my tom senior
there may be 2 or 3 cutters i can spare from duplicates i have
it comes with vise ( very heavy duty) and i will chuck in a vertical attachment that mounts on the over arm bar I took it of to clean so it will need reassembly ( it has a 1 hp 3 phase motor separate for vertical setup that has been reconfigured for delta by professional motor winder but needs to have box for terminals but i think you may have a vertical head to fit it if i recall
6th Feb 2018, 06:57 PM #7Most Valued Member
Thanks John, I don't have a vertical head, there is one for sale to suit a Victoria in Murray Bridge. Will chase that one up later on. Will send you a PM when I'm ready for it, if that's OK with you.
I'll have to get the details of your VFD so I can get one similar.
6th Feb 2018, 06:59 PM #8Member
- Sep 2016
- Canberra
- 89
Good on you Kryn! I reckon I would have bought it if I was closer! 8 hours one way is just too taxing on me these days!
It always warms my cold heart to see old machinery go to good homes!
6th Feb 2018, 07:07 PM #9Golden Member
- Nov 2005
- adelaide
- 597
Kryn we will be away for some time from 1st week in april would like it gone before then
6th Feb 2018, 07:28 PM #10Golden Member
- Nov 2005
- adelaide
- 597
Addison horizontal milling machine
By Petip in forum METALWORK GENERALReplies: 3Last Post: 11th Feb 2015, 06:53 PM -
Bridgeport 1ES horizontal milling machine
By Belair_boy in forum METALWORK GENERALReplies: 10Last Post: 11th Jan 2015, 10:28 PM -
Cheap Horizontal Milling Machine
By jmebgo in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 9th Sep 2014, 07:38 PM -
horizontal milling machine numbers
By tanii51 in forum METALWORK GENERALReplies: 0Last Post: 5th Nov 2013, 09:29 PM
