Results 1 to 1 of 1
8th Jun 2013, 10:45 AM #1New Member
- Nov 2009
- ipswich
- 2
Cig welder transarc tradesman HD (stick/arc welder) 3phase
Up for regretful sale is my 3 phase Cigweld transarc tradesman HD 320 amp welder, as i don't have access to 3 phase power anymore. This heavy duty, dual range, fan cooled, industrial arc welder has infinitely adjustable welding current from 60 to 320amps and is designed to operate from a 415V volt, 32 amp outlet. It is designed to meet the requirements of a tradesman, maintenance personnel and farmers. The dual range welding output accommodates a wide material range including mild steel, stainless steel, alloy steel, cast iron, copper alloys for electrode sizes from 2.5mm to 5.0mm. Please note that i don't have 3 phase power to show that it works but was in perfect working order last time use Located in Ipswich Asking $400 141012 056.jpg141012 055.jpg141012 057.jpg141012 058.jpg141012 059.jpg
Recommendations for Small Stick Welder
By foccacia in forum WELDINGReplies: 53Last Post: 28th Apr 2012, 09:31 AM -
SOLD: CIG Transarc Contractor 3 phase welder
By Avery in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 22nd Feb 2012, 03:38 PM -
Inverter Arc / Stick welder recommendations
By Matty5700 in forum WELDINGReplies: 10Last Post: 17th May 2009, 10:53 AM -
I want to buy a Stick Welder
By 8679 in forum WELDINGReplies: 22Last Post: 2nd May 2009, 11:38 PM
