Results 1 to 5 of 5
8th Oct 2012, 08:22 PM #1Senior Member
- Feb 2008
- Australia
- 146
355mm hot saw, 3 phase motor & VFD, Steel, HDPE, Alumi..... Pickup Mount Annan, 2567
Just getting rid of some stuff I no longer use.
Makita 355mm Friction Saw, paid $360 new, purchased 2009 with minimal use. Hasn't been used for about 12 months as I cannot use it where I'm at. Will give it a cleanup and run if there is any interest.
Asking: $120
Bunch of steel
60x60x1.5mm Pre-gal RHS (2 long lengths I believe ~2.6M-2.7M and a couple of smaller pieces, was given 2x8M lengths instead of 6.5M so had plenty left over from a project)
25x25x2.5mm PTD RHS (1 long 3M length and there should be some smaller lengths there some in 2mm thick)
30x30x6? Hot Rolled? angle
Can check everything if there is interest.
Asking: $20 the lot
1.1KW 3 phase motor & Chinese VFD 2.2KW. I cannot help with setting up the VFD if you want to run another motor, probably best for someone who has used them before. Can be shown running on the lathe, I'm planning to just replace it with a 240V motor as I never use the VFD to change speeds, also the motor is a little large (physical size) for the lathe.
Asking $120 (will separate if $120 is reached through 2 buyers)
Block of 40mm thick HDPE (It should be HDPE but I cannot be 100% certain, machines alright not as good as acetal though) the height is just over 800mm, thought I'd use it but its just collecting dust in the storage unit.
Asking $10
2 pieces of 3mm aluminium checkerplate, highest piece is about 800mm high. (there is a 3rd piece of plate pictured but is not included)
Asking $10?
Aluminium composite panel White color matt one side gloss on the other, one large piece ~1x1.2M and a small piece unsure on the size. corners have crumpled a little on the larger sheet.
Asking $10
Pickup is from Mount Annan, NSW 2567, Cash on pickup only.
9th Oct 2012, 06:37 PM #2Golden Member
- Dec 2011
- 505
10th Oct 2012, 06:43 PM #3New Member
- Mar 2009
- Bathurst
- 7
Hi
I would be interested in the cutoff saw and HDPE if still available. Can you send a pm so we can exchange phone numbers.
Regards Emu243
11th Oct 2012, 02:15 AM #4Senior Member
- Feb 2008
- Australia
- 146
VFD and motor have been withdrawn from sale.
EMU243 both are available, pm sent.
Whatever remains this coming Saturday will be listed up on ebay so if there is any interest with the remaining goods please express your interest by then.
12th Oct 2012, 09:18 PM #5Senior Member
- Feb 2008
- Australia
- 146
