Results 1 to 8 of 8
Thread: Hercus Serial Number
1st Mar 2009, 04:40 PM #1Intermediate Member
- Dec 2007
- Brisbane
- 26
Hi All,
My serial Number reads AU 10889 with the letters RGE on the back slideway and a BS on the front slideway.
Can anyone tell me what these letters and numbers correspond too?
My lathe is the craftsman model 9" with the motor and pulley setup underneth the lathe bed in the cabinet.
Regard marc.
1st Mar 2009, 07:18 PM #2bitza500 Guest
Hi Marc, the Craftsman setup is like the second version of the South Bend that Hercus Copied and they ran that system for years and is a good set up as my mate has a 1929 South Bend with that setup and has never had a problem bar replacing the flat belt of his old lathe
all the best derek
2nd Mar 2009, 02:10 AM #3Member
- Sep 2008
- Prince George BC Canada
- 89
Hi Mark,
The A = Model A (there are models A-b & C
The U = Underbench drive
RGE is the Initials of the inspector that sertified the machine.
the BS I don't know but they all seem to have it.
alRemember if the ID exceeds the OD the hole will be on the outside!
2nd Mar 2009, 05:55 PM #4Intermediate Member
- Dec 2007
- Brisbane
- 26
5th Mar 2009, 04:50 PM #5Member
- Sep 2008
- 89
Mark, what color is your machine?
5th Mar 2009, 06:15 PM #6Intermediate Member
- Dec 2007
- Brisbane
- 26
Hi Al,
My lathe is the standard old hercus green, a bit like army green.
I had to repair and repaint the coolant tray as it was damaged during transport from Sydney to Brisbane.
Got my brother the spraypainter to match the color from the bottom of the tray as it had not seen the light of day in 43 years and was close to original.
The tray looks a bit out of place as the rest of the machine is the old orginal dull green.
Regards Marc.
17th Apr 2009, 04:12 PM #7Member
- Apr 2009
- Boronia Australia
- 49
Hi All
The BS stamping may mean to some British standard or other, but is unusual not to quote a number. The British standard for things was thought to be quite a status thing once upon a time.
22nd Apr 2009, 08:32 PM #8Senior Member
- Canberra
- 184
In the early catalogue that was posted in this forum some time back, B.S. is used to denote the type of drive unit that bolts directly onto the bench (copy of standard southbend drive). The more common vertical type that bolts straight onto the back of the lathe bed (original hercus design) is called paten h.
I think this explains the very early machines that are labelled B.S. No idea why a craftsman has B.S. on it though.
By Anorak Bob in forum THE HERCUS AREAReplies: 1Last Post: 30th Dec 2008, 03:31 AM -
Hercus parts on Ebay from Hercus
By bollie7 in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2008, 02:59 PM -
Hercus Serial Numbers
By Drummond in forum THE HERCUS AREAReplies: 18Last Post: 28th Sep 2008, 10:55 PM -
Hercus 9" Serial Number BS316
By bitza500 in forum THE HERCUS AREAReplies: 12Last Post: 25th Jul 2008, 01:38 AM
