Results 1 to 2 of 2
    Nov 2006
    Heidelberg, Victoria
    79
    2,074
    Default Change gears for Hercus lathe model C?
    Dear members,
    Have been asked to help a friend determine what were the standard change gears that came with the 9" Hercus lathe model C.
    According to the Operator's Manual, there were 13 change gears, 1 idler gear and 2 compound idler gears to cut threads from 4 to 160 tpi.
    What is not mentioned, is how many teeth there were on each gear.
    I have a model A, and am sure the setup on my lathe is different.
    Any help would be appreciated.
    Ken
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Ken you should find for Imperial threads you would require.
    16,24,32x2,36,40,44,46,48,52,54,56,57,60&80 as well as compound gears 72/18& 54/18.
    If Metric thread cutting is required 6mm pitch to 0.20 pitch the following gears are required,
    16,18,20,22,24,26,28,32x2,36,40,44,48,52,56,80&100 as well as compound gear 127/100.
  1. Hercus 9" back gears
    By Buncha in forum THE HERCUS AREA
    Last Post: 23rd Sep 2008, 12:10 AM
  2. new C MODEL HERCUS OWNER
    By beetle in forum THE HERCUS AREA
    Last Post: 31st Jul 2008, 12:19 AM
  3. Hercus Quick change blocks
    By Penpal in forum THE HERCUS AREA
    Last Post: 9th Jul 2008, 01:39 PM
  4. Replies: 10
    Last Post: 10th Jun 2007, 10:37 AM
  5. Hercus Gear Change Plate
    By John Richards in forum METALWORK GENERAL
    Last Post: 16th Feb 2007, 01:24 AM
