Results 1 to 15 of 21
Thread: Hercus 9" back gears
22nd Feb 2008, 12:56 PM #1Intermediate Member
- Feb 2008
- 35
Hi, I'm new to this forum. Looks like there are a lot of clever people here
Does anyone know where I can get a new or used back gear for a Model C Hercus? I need the gear on the RH end of the back gear shaft.
Buncha
22nd Feb 2008, 01:09 PM #2
Mick Moyles may be your best bet.
I was there a few weeks back, and he had what you are after.
If you e-mail him, he should be able to post the gear to you.
http://www.moyles.com.au/
25th Feb 2008, 04:50 PM #3Intermediate Member
- Feb 2008
- 35
Back gears
Thanks for the tip Fossil.
I rang Moyles but unfortunately the parts were already sold. It looks like I'll have to do some dentistry.
5th May 2008, 02:23 PM #4bitza500 Guest
chasing a Gear???
Hi, I am currently having a box of Southbend parts that I am buying to restore my 1938-39 Hercus 9" if you can let me know all the dimensions and number of teeth I can see if my Mate in America can track you one down as so far all the parts 9 boxes have fitted the Hercus so let me know as in America it is big business wrecking lathes and a lot of parts available
all the best derek
13th May 2008, 01:23 PM #5Intermediate Member
- Feb 2008
- 35
Derek,
thanks a bunch for the offer.
The gear is 1.5" diameter, 24 teeth, cast into a shaft 6" long that also has a 4" diameter gear with 62 teeth. The shaft has a 3/4" bore I think. The pitch between the gears is 4.5".
Greg,
13th May 2008, 05:52 PM #6Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Buncha,
The gear you are referring to is part and parcel of the back gear. It is a one piece casting comprising both gears and barrel. I'm sure someone could repair it, but feel the repair would be more expensive than a replacement back gear.
There is a Seller on eBay USA, that sells many South Bend components.
His ID is ANTFARM200. Open eBay, and click on COMMUNITY. Type his ID in the box, and proceed from there. Click on Items for sale, and select any item referring to 9" South Bend. When this page opens, click 9" South Bend in the LH panel, and you will have an entire list of South Bend parts only. Hercus is a clone of the 9" South Bend lathe with many parts interchangeable.
He does not have a back gear listed at the moment, but it might be worth asking him the question.
Hope this helps.
Ken
14th May 2008, 04:12 PM #7Intermediate Member
- Feb 2008
- 35
Ken,
Thanks for that. I did realise that it was all a one piece casting. I was thinking that I might have a go at repairing it myself, seeing as it's knackered already I can only improve it. But if a replacement part is not too expensive I'll use it instead. I don't want to over-capitalise the lathe. I paid $400 for it, and it is in pretty poor condition.
I was going to buy a chinese one from Hare & Forbes but some mates who are 'experts' talked me into this bargain I found that the tailstock is approx 40 thou lower than the headstock. I've put some loose shims under it for the time being, but will look at doing something more permanent in the future.
Greg
14th May 2008, 07:43 PM #8
Greg
It would appear the tail stock is from another lathe. A common occurance was a large number of Hercus lathes were ex schools etc or commercial users, when put up for sale insiders, sometimes dealers mislaid tailstocks etc to bring the price down ending up not getting the sale occasionally and the mismatch begins.This could be likened to one man in the army losing his towel.
However the tail stock is in two parts,should be easy to modify the height.Arrange with Ken to visit and see, he by now is intimate with his Hercus and lives in Melbourne.
Peter
15th May 2008, 02:01 PM #9Intermediate Member
- Feb 2008
- 35
Penpal,
If this lathe was in a school then there were very dirty little children using it .
It looks like it was worked hard for most of its life without being cleaned. There is oily grime oozing from it. The tailstock miss-match is caused by wear where it rests on the ways, but splitting it and shimming it up is probably much easier than the alternative.
Greg
15th May 2008, 09:39 PM #10Most Valued Member
- 4,890
Just wondering has the tail stock got the same part no as the bed,just seems like a hell of a lot of wear for a tail stock.
16th May 2008, 12:05 AM #11
You don't know the half of it !
They all want to use it.Very few want to learn the theory or safety behind the operation of the machine.
They do not want to pick up tools or clean after the (play ) is done.
I steadfastly refuse to let 9s or 10s use the lathe until the pass a theory and safety test. For the abuse the machines have taken they are something else.Chinese crap lathes would be faaaarcked in minutes.
Some Hercus lathes in schools have 25 years of service.
Under normal operation operated by caring operators, they are great machines.
16th May 2008, 12:40 AM #12Product designer retired
- Nov 2006
- 79
- 2,074
Tailstock gone walkabout
Paul,
My old mates Pete and Grahame, are spot on. Kids slide the tailstocks off and chuck them on the floor in amoungst the swarf. The cleaner comes along, just doing his job, and moves them, and so on etc etc.
I have the same problem with my Hercus in that the serial No's don't quite match. Two digits out, may as well be two hundred digits out. Each Hercus lathe had the tailstock hand matched to the bed. I won't know what problems I face until I finish my restoration.
I have a friend who knows how to align a lathe using a laser sight, will get more info if you need it. It may just be that the tailstock end of the bed needs adjusting.
As Pete suggests, if you want to have a natter about "the old girl" send me an email or PM.
Might be able to help with a few more of your questions.
Ken
16th May 2008, 04:39 PM #13Intermediate Member
- Feb 2008
- 35
Ken,
Thanks for the info on the South Bend guy in the US. He hasn't got a back gear at the moment, but I'll keep checking. I may give the 'Experts' who talked me into it a project to make me a new gear
I havn't checked the serial numbers yet. I'll take a look on the week-end. I have a few other projects that need TLC at the moment, so the lathe is a low priority. I'll get in touch when I have more time to devote to it.
Cheers, Greg
5th Sep 2008, 02:21 PM #14bitza500 Guest
How is the Hercus going
Hi Greg, how is your Hercus coming along as I am now finished bringing in bits due to POVERTY did you ever get the back gear ??
all the best Derek
5th Sep 2008, 08:57 PM #15Most Valued Member
- Charlestown NSW
- 1,673
Greg
I don't know where you are at with your lathe at the moment but did you try Hercus themselves? Still in business still making lathes etc They might still have spares
http://www.hercus.com.au/
regards
bollie7
Moving a hercus 9" lathe...one man job?
By Greg Q in forum METALWORK GENERALReplies: 17Last Post: 9th Apr 2008, 03:57 PM -
9" Hercus tailstock disassembly
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 19th Nov 2007, 01:47 PM -
Adapting quick change tool post holder to suit Hercus 9" lathe
By neksmerj in forum METALWORK GENERALReplies: 10Last Post: 10th Jun 2007, 10:37 AM
