Results 16 to 30 of 38
22nd May 2019, 07:27 PM #16
22nd May 2019, 09:18 PM #17Most Valued Member
- 2,671
Hi Moz.
Managed to find it, but unfortunately it's not in particularly good condition in the bore.
Better to just buy a new one I reckon.
22nd May 2019, 09:33 PM #18
No worries Steve, thanks so much for having a look, anyhow.
And thanks to everyone else who has chimed in with wisdom and offers.
Moz
22nd May 2019, 10:13 PM #19Most Valued Member
22nd May 2019, 10:17 PM #20
Kryn -
Have not raced in a couple years but still have race bike (in avatar) and will get back into it. Pitted for nephew recently at ASBK/Asia Cup round at The Bend. Always working on, modifying, riding bikes, hence why stumbling across my Hercus has been such a blessing. Flywheels to skim, race pegs to turn, brackets, bosses and widgets to make!
Yet to ride The Bend but have done plenty of time at Mallala as well as Phillip Island.
Moz
22nd May 2019, 10:43 PM #21Senior Member
- Jul 2012
- Griffith NSW
- 435
MT2 reamer sets can be had for 24 bucks and up on ebay right now. Thats where I acquired mine and it works a treat.
I was in the exact same position as OP, very good quality 260 for peanuts and otherwise damn near flawless apart from a tailstock quill that had seen some spinning arbors in its time. It took 10 minutes to give it a tickle with the reamer and it has a substantial improvement in bearing area and the taper is smooth and perfectly serviceable. I didnt want to dig to china in there, youre introducing the possibility of an error of alignment with more material removed. I checked the fit against freshly ground MT2 tapers and it was happy days.
I cant fathom that people here are encouraging purchasing a $135 replacement part without giving a $24 tool and a few minutes of careful twirling a go first. The quill, even if the bore is pretty damn chewed up, is repairable with the tools you have, plus that reamer. Even if its a complete abortion, you can put your quill in your lathe, with the compound dialed in on a known good taper, rebore the quill and then ream to achieve good surface finish. To adjust the depth spec of the taper, you just face the end of the quill off to suit. we're not talking big hacks of material here, its gentle massaging back to spec.
$135 bucks...damn, id make one before I went that route...
22nd May 2019, 11:02 PM #22
Scotty - I appreciate your point of view on this.
Kryn has offered to loan me a reamer, so this might be my first port of call in this pursuit. I hope I won't need to go so far as reboring the quill afterwards as at the moment this is way beyond my skill level (I probably have about 8 hour's total time on a lathe in my life...) but I'll sure give the hand reamer a go to start with.
Again, thank you for your advice and wisdom.
Moz
23rd May 2019, 08:56 AM #23Senior Member
- Jul 2012
- Griffith NSW
- 435
I can appreciate that 8 hours isnt exactly a mountain of experience, but all the best learning opportunities are needs driven. The skills youd learn, setting up in a 4 jaw chuck, setting the compound slide, boring a hole and reaming the hole. None of those things are super difficult and all are super useful skills to learn.
I tell you what, if youre not keen to give it a go, I will. If you cover postage both ways to my place, ill repair your quill. Ill take pics of the process and everyone else can learn with us.
23rd May 2019, 02:21 PM #24
Hi Scotty.
Really appreciate the offer but hey, I'll give it a go - first with reaming, then the drilling/boring route. The way I see it, if I stuff it up too badly, the decision to buy a new quill then makes itself, right?
And I always did okay with the 'give it a go' approach when learning ACDC Tig welding. Completely different discipline to turning, but as you said, still very much needs based.
Thanks again for offering to help.
Kym
23rd May 2019, 10:43 PM #25Most Valued Member
When you've got your tailstock sorted you might want to make one of these: https://www.youtube.com/watch?v=bfUXDsh9NqU
I think that will be a project for this weekend for me.Chris
23rd May 2019, 10:47 PM #26
Hey, nice idea...thanks for sharing!
Moz
26th May 2019, 11:52 AM #27
Update on this for those still awake:
Did some practise turning on Friday, just turning up a dead centre, with pretty good results. Limited in materials...would like some cold rolled bar but only have (ex aerospace, long story) high quality stainless bar. Probably a sin to be practising with such nice material.
Chips are lethal!
Getting an okay finish with a WNMG neg rake insert. Wasn't sure the Hercy would have the grunt to work with this but is seems to cope just fine as long as I don't dial in too deep a cut.
Keen try try turning a Morse taper but pretty sure stainless would not be the way to go - finish, workability, galling? Who knows, I'm new at this.
Will post pics later.
Moz
26th May 2019, 10:25 PM #28
A couple pics of me turning up a centre using some SS bar.
Nothing spectacular, just learning pics. Have since revisited this - spun the spindle speed up higher and changed the angle from 45 to more like 60 degrees. All good fun, lots of nasty SS chips hanging around like an afro made of razor wire...
Moz
26th May 2019, 11:02 PM #29Most Valued Member
- 4,890
60 degrees is what you want.
Was there a particular reason why you were cutting the taper with the compound set that particular way, you are working very close to the chuck.
26th May 2019, 11:08 PM #30
Yeah, 60 degrees is what I have now, so happy with that.
Setting the compound that way was a mistake, pipeclay. Just teaching myself, learning as I go. Always very conscious of what is where, but not beyond the occasional cognitive stall, that's for sure. Finished this job, stood, stared, slapped myself, set it up differently (safely).
Appreciate your concern - I am always open to pointers, very happy to hear any and all tips. Literally no-one else I know has a lathe at the moment so this is between, me, YouTube and you guys.
Moz
Replace Bull Pin ? : Hercus 9" Model A :
By steamingbill in forum THE HERCUS AREAReplies: 7Last Post: 9th Oct 2018, 06:50 AM -
Hercus 9A Tailstock Reassembly Problem
By AntJS in forum THE HERCUS AREAReplies: 5Last Post: 14th Jan 2013, 10:40 AM -
Hercus Camlock Tailstock
By bitza500 in forum THE HERCUS AREAReplies: 0Last Post: 29th Jan 2010, 11:23 PM -
Extending tailstock quill travel
By Big Shed in forum METALWORK GENERALReplies: 6Last Post: 16th Dec 2009, 09:07 PM -
9" Hercus tailstock disassembly
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 19th Nov 2007, 01:47 PM
