Results 1 to 7 of 7
    Aug 2015
    Melbourne, Australia
    843
    Default Hercus Hackasaurus - where is the serial nr?
    Hi all,
    New to this part of the forum. I am giving some new life to a tired old Hercus Hacksaw. From what can tell from the scant info available, I suspect it is maybe late 30's at earliest and late 40's at latest - but I am no expert.
    I am doing a nut and bolt on it but have seen no serial number stamped anywhere.
    Did they have the SN stamped on castings or a plate? If a plate - no chance then - all gone.
    All help appreciated.
    Greg.
    Adelaide
    68
    1,373
    Quote Originally Posted by StrayAlien View Post
    Hi all,
    Greg.
    Just ducked out to have a look at mine, probably around the same vintage, and I cannot find a serial number anywhere either. There's a brass makers plate detailing the oils to be used on the left of the saw and a McPhersons (the reseller) badge on the front but that's it. There's no sign of any missing plates either.
    Rgds - Gavin
    Aug 2015
    843
    Thanks Gavin,
    Any excuse to duck out to the shed during the evening eh - good man - I do the same!! he heh.
    I have two small holes on mine that look like it could have been for a plate - but that is about it. I've not seen a SN anywhere - even under the 'tub'.
    What chance of a pic of your oils plate?
    Adelaide
    68
    1,373
    Thanks Gavin,
    I'll have a go at it, it's pretty worn though.
    Aug 2015
    843
    Thank you Gavin - doesn't need to be anything special. I'll not be reproducing anything from it! ... yet .... I am more curious than anything. I am new to the Hercus world ... (though I do own a South Bend lathe - but a 10" not a 9").
    Adelaide
    68
    1,373
    Here are some photos of the 2 plates on mine, one is the original oil spec plate from FW Hercus, the other would have been affixed by the reseller.
    Aug 2015
    843
    Thanks Gavin - much appreciated.
    You have a rubber seal on the lift!! Fancy stuff.
    There are no rivet holes on my machine in that area. Interesting.
    Thanks again,
    Greg.
  1. Hercus Hackasaurus - how to make mobile, but stable when in use?
    By StrayAlien in forum METALWORK GENERAL
    Last Post: 16th Jun 2019, 08:21 PM
  2. Anyone have Hercus 9 Serial 8616 ?
    By karlxx in forum THE HERCUS AREA
    Last Post: 3rd Apr 2014, 01:59 PM
  3. hercus serial no
    By tryhard202 in forum THE HERCUS AREA
    Last Post: 5th Nov 2012, 09:03 PM
  4. Hercus Serial Number
    By Mark2 in forum THE HERCUS AREA
    Last Post: 22nd Apr 2009, 08:32 PM
  5. Hercus Serial Numbers
    By Drummond in forum THE HERCUS AREA
    Last Post: 28th Sep 2008, 10:55 PM
