Results 1 to 6 of 6
    Oct 2011
    Sydney, NSW
    1,249
    Default 3C Collet Set and Closer
    Hi,
    I recently bought a Hercus 9'' 3C Collet set and Closer from Gumtree for my 260ATM.
    I tried using it today, it came with a morse taper adaptor but I think it's the wrong size.
    Has anyone used a Hercus 3C set on a 260? Did Hercus make a adaptor that fitted the 260? I've tried Mal's site but couldn't see anything.
    Cheers Ben.
    Oct 2010
    NSW
    181
    Hey Ben, I think you'll find that the 9" has a No 3 morse taper while your 260 is a No 4.
    Cheers John
    Jun 2013
    Tasmania
    257
    The above info is correct.
    Oct 2011
    Sydney, NSW
    1,249
    That is correct, I remembered I bought a 4MT centre last year.
    So, where do I get a correct sized taper sleeve?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    You may have to buy a 3/4 sleeve and cut the tang off so that you can get the draw tube to screw onto the collet.
    Oct 2011
    Sydney, NSW
    1,249
    Thanks Pipeclay, I just read about someone doing the same thing.
    Ben.
  1. ID grinding an ER collet?
    Last Post: 9th Mar 2017, 10:52 PM
  2. 2MT v's R8 collet
    By DaveTTC in forum METALWORK GENERAL
    Last Post: 11th Apr 2014, 06:50 PM
  3. Collet Question
    By bwal74 in forum THE HERCUS AREA
    Last Post: 19th Jun 2012, 08:16 AM
  4. setting is getting closer to completion..
    By Corgan in forum METALWORK GENERAL
    Last Post: 30th Nov 2011, 07:19 PM
