Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Aug 2016
    Adelaide
    80
    Default machining compound slide mounting spigot
    Any advice on best way to machine the tapered section of the hercus compound mounting spigot, the part that goes into the cross slide? What angle is it meant to be?
    Nov 2018
    Tasmania
    97
    Quote Originally Posted by monchochos View Post
    From memory when I saw mine ages ago it would be a 45°ish cone
    I'll measure when I get home
    Jun 2007
    sydney ( st marys )
    64
    4,890
    30
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    To machine the spigot I'd either set up on a rotary table with a milling cutter or if I had a lathe big enough, put it on a face plate. It depends a bit on why you are machining it too. Are you repairing damage, making up from new or devising an accessory that fits in that place? You may be limited by the part size and weight.
    Aug 2016
    Adelaide
    80
    I'm making an accessory to fit in it's place, just a fixed toolpost stand out of some 90mm round. I will be turning it on the lathe as I don't have a mill. I usually get a lot of chatter with form tools so I'm thinking of setting compound at the correct angle, grind a suitable RH turning tool and machine up to the left/top shoulder. Or is there a better way?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    That will work,I find that the easiest way.
    Nov 2007
    melbourne australia
    3,228
    Would you please post some pics of the tool post when it’s finished?
    Sent from my iPad using Tapatalk
    Aug 2016
    Adelaide
    80
    It will be a platform for toolpost to sit on top but sure.
    Nov 2007
    melbourne australia
    3,228
    I assume you’re trying to increase rigidity by removing the top slide?
    Aug 2016
    Adelaide
    80
    I have trouble with the compound moving with chattering when parting off. I thought I could take it out of the equation. Also might be useful for other jobs.
    I've not had much success with parting off yet. Almost every time something scary happens.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Are you using a lantern post or 4 way?
    Are the gibs adjusted to reduce slop?
    Do you lock the carriage when parting?
    Aug 2016
    Adelaide
    80
    4 way QCTP. I wouldn't call the gibbs sloppy, though the compound is free to move. I could perhaps tighten it a bit. I lock the carriage.
    Not sure where all the chatter is coming from. The machine is on casters at the moment which is probably not helping. I do use the QCT holder for parting blade which has a built in angle which I think contributed to my last "scary moment". Do others use back rake in their parting tool?
    Feb 2014
    Newcastle NSW
    78
    Default I'm embarking on a similar project building a milling attachment for my Hercus.
    Feb 2014
    Newcastle NSW
    78
    And yes 30 degrees is the angle you are after
  15. #15
    Aug 2016
    Adelaide
    80
    Perfect, thanks.
  1. Setting the compound slide.
    By th62 in forum METALWORK GENERAL
    Last Post: 2nd Sep 2014, 09:52 PM
  2. Compound Slide
    By bwal74 in forum THE HERCUS AREA
    Last Post: 10th Apr 2014, 12:20 PM
  3. Compound slide trouble..
    By Kon R in forum METALWORK GENERAL
    Last Post: 8th Jul 2012, 03:36 PM
  4. Compound slide problems.
    Last Post: 27th Jan 2010, 08:34 AM
