Results 1 to 4 of 4
    Feb 2014
    Newcastle NSW
    78
    Default Hercus C model cross slide backlash....
    Just after some advice on how to minimise the backlash in the cross slide.
    I plan on slowly restoring the old girl over time to as close to origional condition as possible.
    https://www.youtube.com/watch?v=aM5leCZa0nY
    Jun 2007
    sydney ( st marys )
    64
    4,887
    That's more slop in nut and screw than backlash.
    Feb 2014
    Newcastle NSW
    78
    Ah ok thank you! Is there a way to adjust it or will i need to replace both the nut and screw?
    Oct 2004
    Southern Highlands NSW
    1,894
    Some backlash won't hurt, but it's nice if it's not excessive.
    First reduce the play that is a result of wear at the thrust collar - instructions in manual.
    Then if it's still too much it's due to wear of the leadscrew and/or the nut.
    There was someone selling adjustable split nuts for South Bends in USA, maybe still available.
    That would deal with nut wear as it develops, but if the leadscrew is also worn you can only adjust the nut until it's just free at the tightest point on the screw.
    The leadscrew could be replaced as a whole, or a new threaded Acme(?) threaded rod could replace the thread only.
  1. Cross Slide Scraping Hercus 260
    By Abratool in forum THE HERCUS AREA
    Last Post: 14th Nov 2014, 05:06 PM
  2. Backlash in Hercus 260 cross-slide
    By jack620 in forum THE HERCUS AREA
    Last Post: 4th Mar 2013, 06:19 PM
  3. Hercus 260 Cross-slide play
    Last Post: 26th Sep 2011, 08:47 PM
  4. South Bend/Hercus Cross slide nut
    By YarrD in forum THE HERCUS AREA
    Last Post: 14th Dec 2010, 11:34 PM
  5. Hercus Extended Cross Slide Casting
    By Swarfmaker1 in forum THE HERCUS AREA
    Last Post: 3rd Dec 2010, 07:18 AM
