Results 1 to 4 of 4
Thread: MT3 Collets for Hercus O Mill?
16th Feb 2019, 08:06 PM #1Intermediate Member
- Aug 2014
- Brisbane
- 38
Hi All,
I am looking into a collect / chuck setup for the vertical head and was going to go with a ER25 MT3 and make my own drawbar as I have seen on one of these posts.
I have since came across these on the Hare and Forbes website and they looked like a good or even better idea. Unless I am understanding it all wrong... Which could very well be the case.
Does this go directly into the morse taper on the vertical head and remove the need for a collect chuck? As it is 1/2" thread I could also use the same drawbar that came with the fly cutter??
I assume it would also increase the Z axis? If so that would be great as I dont have the standard Hercus vice, the one that come with my mill is larger and reduces the Z height even more.
I would appreciate any input if I am on the wrong track.
https://www.machineryhouse.com.au/C135
16th Feb 2019, 09:37 PM #2Most Valued Member
- 5,942
Yes, they go straight in. Looks to be a good idea, provided that you only want to use milling cutters with either 6, 10, 12, or 16mm shanks on them.
17th Feb 2019, 02:06 AM #3Golden Member
- Cairns, Q
- 666
I have a set of the 3MT collets in the common metric tool shank sizes, and another in the common Imperial tool shank sizes, which I bought in the early nineties when I bought my mill (not a Hercus, but I think the same comments apply). I have since switched to ER32 collets, because they are more versatile, and can be used more conveniently for work holding in the lathe. However, I would not part with the MT3 collets, because their outstanding advantage in the mill is that there is virtually no lost headroom when they are used: the collet is almost completely swallowed in the spindle, saving maybe 40 or 50 mm from when a collet chuck is fitted.
The 3MT collets can also be used for holding short workpieces in the lathe, but they are of limited value for this purpose since they are size specific, unlike the ER collets where each collet can cover a range of workpiece diameters, and workpiece length is limited by the presence of the draw bar. I notice H & F's 3MT collets have gone down $11 in price since I bought mine.
The ER collets are more convenient to use with their front mounted tightening nut for both tool changing in the mill and work holding in the lathe, but in the mill they will cost you headroom which may be critical for some jobs. A further advantage of the ER collets for work holding in a lathe is that if they are mounted in a spindle nose chuck which does not require a drawbar long workpieces can be accommodated because they can pass through the lathe's hollow spindle.
Frank.
17th Feb 2019, 05:10 PM #4Intermediate Member
- Aug 2014
- Brisbane
- 38
Thanks Kryn and Frank
Appreciate the info. I didnt foresee some of those negative although they are obvious now...
Also didnt even think of using it in the lathe.
I think at this stage I will go with a couple of sizes and the matching end mill to get me started.
See how I go from there....
At this stage I dont have a specific need for the Mill, just love making and fixing stuff, so I assume I will collect more bits for it along the way!!
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Hercus O Mill
By bwal74 in forum THE HERCUS AREAReplies: 10Last Post: 6th Jan 2013, 03:52 PM -
Hercus 260 lathe Collets & Adaptors
By Abratool in forum THE HERCUS AREAReplies: 3Last Post: 20th Aug 2011, 12:39 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Hercus Mill
By PBrown in forum METALWORK GENERALReplies: 5Last Post: 6th May 2009, 01:04 AM
