Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Jan 2012
    88
    Quote Originally Posted by nadroj View Post
    Good access to terminals and capacitor too, as long as you can get behind the lathe.
    Does it have a brand name?
    Vevor, model description was YL8024 - 0.75kw
  2. #17
    Oct 2010
    NSW
    177
    Excuse my ignorance, but when they say these motors are reversible does that mean switch reversible or just that they can be wired to run one way OR the other.
  3. #18
    7,183
    Quote Originally Posted by Picko View Post
    It usually means not having to open up the motor to get at the junctions needed to set up for reverse operation. ie enough connections available inside the junction box to make then switch reversible.
  4. #19
    Sep 2008
    Queensland
    445
    Damn It after months of thinking off and on about this problem its suddenly very clear they changed the casting
    Mine compared to rickw72
    happy turning
    Patrick
  5. #20
    Sep 2008
    Queensland
    445
    Default Done
    I just though this needed a conclusion if anyone else runs into this problem. I machined it out at work fairly easy I centred the boring head then wound out the diameter to just lick each side then fed Y in to a depth where it looked about right. It worked well and looks like the pictures I had seen now I just have to finish the project.
    Hope this helps
    happy turning
    Patrick
  1. Single phase motor for Hercus
    By jamie_c in forum THE HERCUS AREA
    Last Post: 2nd Jan 2018, 03:30 PM
  2. Powering a 3phase pump with single phase
    By MOA in forum METALWORK GENERAL
    Last Post: 15th Jul 2015, 06:59 AM
  3. TECO Single Phase Motor for Hercus No.O
    By Anorak Bob in forum THE HERCUS AREA
    Last Post: 23rd Jun 2015, 07:44 AM
  4. 5.5HP 3Phase motor on Single Phase with a VFD ????
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 1st May 2015, 11:28 PM
  5. 3phase on single phase plus a capacitor ?
    Last Post: 8th Feb 2015, 10:25 PM
