Results 1 to 6 of 6
    Nov 2018
    South Austrailia
    72
    4
    Default The Kingston Hercus 260
    A quick question - the cheap VFD has input of single phase 240 volt and out put of 220 volts on each of the three phases and my electrician says that it will not work with the three phase motor which needs each phase at 415 volts - did I get the wrong VFD cheers Keith.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    The motor has to be configured as a delta winding rather than the standard star winding. Once that has been done it should all work. Others here have converted their motors or if you are not interested in doing that personally, then a trip to a motor rewinder's.
    Tennant Creek, Aust
    61
    600
    Dont know if this will help a Hercus 9 AR wiring diagram.
    Nov 2007
    melbourne australia
    3,228
    That diagram shows a single phase motor. Keith's is 3 phase.
    Jan 2019
    epidermis
    73
    6
    Hi Keith,
    here is a picture of my single phase VFD with three phase output to the 3ph lathe motor . . .
    john
    VFD controls lathe RS.jpglathe stand ready for lathe and chip tray RS.jpgMotor Specifications RS.jpg3ph motor wiring options RS.jpg3ph wiring.jpgLathe manufactured 1981 RS.jpglathe stand complete RS.jpg
    hope that puts the matter beyond reasonable doubt?
    john aka castellated nut
    Jan 2019
    epidermis
    73
    6
    Default VFD single phase input three phase output
    Hi Keith,
    john
  1. Hercus 9" vs hercus 260 ????????
    By bitza500 in forum THE HERCUS AREA
    Last Post: 26th Jun 2009, 10:50 PM
  2. Hercus parts on Ebay from Hercus
    By bollie7 in forum THE HERCUS AREA
    Last Post: 8th Oct 2008, 02:59 PM
