Results 1 to 8 of 8
Thread: Purchased a Hercus 260
19th Dec 2018, 01:53 PM #1New Member
- Nov 2018
- South Austrailia
- 72
- 4
Thanks to the person who gave me the specification sheet to the 260. The lathe was waiting at Graysonline in Melbourne and was picked up and is now home near Kingston in the South East of S.A.(model ATM no. 19490) The lathe has a 0.55kW three phase motor and I need to be able to plug it in to a normal 240 volt plug. Looking at other posts, I need a VFD and on contacting my local electrician, he found one for approx. $700. I looked on eBay and found one that is 0.75 kW, 5 amp for about $70 - who's on the right track?
19th Dec 2018, 02:13 PM #2Member: Blue and white apron brigade
The local electrician might be choosing the $700 VFD because that is a brand he is familiar with and he might already be familiar with the parameter settings. VFDs all have a slightly different list of parameters and it can become a right PITA and consume lots of time to install a different VFD with different parameters.
Remember if your sparky instals the VFD he kind of guarantees it will work so he wants to minimise his actual and possible cost and time so he won't necessarily be choosing the cheapest option. You might have to wear the warrantee on the $70 VFD and learn how to program it yourself.
Nevertheless there should be no need to spend $700 for a 1HP VFD.
One more very important thing - DO NOT buy any VFD that you have not seen the manual for. The manual is critical during the installation and subsequent programming and some of the chinglese manual have many mistakes and some are completely incomprehensible . Ask the supplier/vendor for an e-copy of the manual before you buy it and if you are not going to be installing it make sure the sparky has seen and understands the manual.
19th Dec 2018, 02:53 PM #3Intermediate Member
- 26
Another item to look out for is the complexity of drive. Some are very simple and you only need to set very basic parameters in order for them to work. If this will suit your application i would recommend the simpler drive (it generally will be cheaper). I have just rewired a lathe and put a fancier drive in. I could get it to work the basics but in order to program the drive to enable all the features i wanted took quite some time and a lot of trial and error despite a reasonably thorough manual. I have now gotten the drive to run all of the existing controls of the lathe (apron forward/reverse) variable speed dial on the control panel, active braking, jogging and different accelerations in forward/reverse and emergency stop. There is a lot more that you can achieve with the drives just a matter of programing and wiring the correct switches/controls.
19th Dec 2018, 03:05 PM #4Most Valued Member
It's worth installing a VFD yourself, assuming you are competent to do so. Not only will you save about $500, but you are probably going to want to fiddle with the parameters like acceleration/deceleration times after you've had time to use it. If you install it yourself you'll know how to do this. If your sparky installs it, you'll either have to call him back or learn how to do it anyway.
I installed one of these on my Hercus 260: https://cononmotor.com.au/product/0-...erter-vsd-vfd/
A word of warning- don't set your deceleration time too short or your chuck can unscrew. My faceplate unscrewed on me. Fortunately no damage was done to the lathe or faceplate.Chris
20th Dec 2018, 10:57 AM #5New Member
- Nov 2018
- South Austrailia
- 72
- 4
Thanks for the replies, I have ordered a cheap one and so hopefully cant loose too much - have a great Xmas and New Year (safely)
20th Dec 2018, 08:47 PM #6Golden Member
- Nov 2005
- adelaide
- 597
dont forget you need to get the motor wiring changed to delta if it isnt already... have a look inside the box on the motor and see if its got 6 connections if not you will have to get it modified by a motor rewinder if you dont know how to do it \
i use a vfd on my hercus 260 DGLMH
20th Dec 2018, 09:30 PM #7Member: Blue and white apron brigade
Some motors on Hercus machinery have 4 terminals/connections and can also be easily modified without taking it to a rewinder.
When connected in star formation three of the connections will have 2 wires connected (one from the mains and the other to the inside of the motor) and the 4th connection will have 3 wires connected to it from the inside of the motor. (see red arrow in picture - it doesn't look like it but there are 3 wires connected to that terminal).
These 3 wires need to be disconnected from each other and usually may need an extension and then connected back to the other terminals in a specific sequence. A half decent sparkly should be able to do this.
This one is from my Hercus mill.
20th Dec 2018, 09:46 PM #8Diamond Member
- Aug 2006
- 1,106
If you had to take it to a sparky to be rewound you might be better off sourcing a new or second hand motor already set up to take 240V 3 Phase, could also be a good opportunity for a upgrade to a larger motor.
Changes to GST on goods purchased overseas
By simonl in forum METALWORK GENERALReplies: 15Last Post: 3rd Jun 2018, 10:40 AM -
Purchased Machienry houses Tig / Mig / MMa
By simso in forum WELDINGReplies: 49Last Post: 10th Sep 2013, 07:16 AM -
Hercus 9" vs hercus 260 ????????
By bitza500 in forum THE HERCUS AREAReplies: 1Last Post: 26th Jun 2009, 10:50 PM -
Hercus parts on Ebay from Hercus
By bollie7 in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2008, 02:59 PM
