Results 1 to 5 of 5
11th Dec 2018, 09:23 PM #1Member
- Nov 2018
- Tasmania
- 97
Model A Apron on Model C Hercus Lathe?
Random question out of curiosity
I have a Model C lathe with no power crossfeed, but I see Model A aprons come up on gumtree sometimes
Is it possible to mix and match, or is the leadscrew unique to model A or in a different position?
Anyone have any Model A lathes to compare with?
Oh and I'm talking a 9 inch varient
12th Dec 2018, 12:35 AM #2Most Valued Member
- 4,890
You will need to use a leadscrew with keyway to get your feeds, either an A or B or even your C if you cut the keyway,
12th Dec 2018, 07:30 AM #3Senior Member
- Jul 2012
- Griffith NSW
- 435
Youll need to replace a bunch of parts. leadscrew, crossfeed screw, the apron and add a quick change gearbox. The screws that come with the A and B variants have a shorter leadscrew to account for the QCGB.
17th Dec 2018, 07:41 AM #4Member
- Nov 2018
- Tasmania
- 97
Maybe I just need to look out for a Model A Hercus!
You guys are talking about a keyway in the leadscrew, how does that fit in with the half nuts? (I'm picturing a full length key with a gear that slides with the carriage??)
17th Dec 2018, 09:11 AM #5Most Valued Member
- 4,890
If you look for a photo of an A carriage you will see a Star wheel, this has a worm and wheel behind it or somewhere in there, this provides the surfacing and sliding feeds when the desired direction is selected and the Star wheel/Clutch is tighten to engage the worm and wheel.
For threading the feed selector is placed in neutral and the half nuts are engaged , the half nuts clamp on the leadscrew ,the keyway causes no problem running through the half nuts.
Magazines in need of a home - Aust Model Eng, Model Eng, Model Eng workshop
By DarrylB in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 7th Mar 2018, 06:20 PM -
An unusual later model Hercus lathe
By kwijibo99 in forum THE HERCUS AREAReplies: 3Last Post: 23rd Jun 2016, 12:50 PM -
Model A - black finish on apron
By Justin Wright in forum THE HERCUS AREAReplies: 0Last Post: 11th Nov 2015, 02:23 PM -
Hercus Model AR lathe
By Shikyo in forum THE HERCUS AREAReplies: 8Last Post: 16th Jul 2013, 04:30 PM -
hercus model A 1951 model
By pjh4159 in forum THE HERCUS AREAReplies: 5Last Post: 21st Aug 2011, 03:15 AM
