Results 1 to 5 of 5
    Apr 2018
    Sydney
    64
    Default Hercus 260G spindle wrench modification
    Made a small modification to my lathe. I know a circular engagement with the spindle isn't ideal, but it was the easiest to make at this point in time.
    Gets the job done, sits nice and snug in the back of the spindle. Now the chuck can be removed without having to go into low gear and risking damage to the gears, etc.
    It is now similar to the spindle on the Emco V10 P.
    And yes that small 8mm bolt is enough to do the job, I could probably use the wrench as a hammer if need be.
    45088622_890429737820140_2761576023282679808_n.jpg45134475_2306606286036149_6629116918538174464_n.jpg45170234_609757519469923_3671825884186148864_n.jpg45227972_268845850439569_277989426066358272_n.jpg
    Jun 2007
    sydney ( st marys )
    64
    4,887
    What holds your plug in place on the grooves you have cut?
    Apr 2018
    Sydney
    64
    Some length of the socket goes into the spindle to help keep it in place (a little too loose on my one). A pin is inserted through a hole drilled in the socket which fits into the 2 small grooves cut on the spindle. It holds pretty well for a round groove (will need to make a tighter socket in the future).
    When the chuck needs to be removed, the wrench can be set against a block of wood and a spanner placed on one of the chuck jaws and it comes right off.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    So are you still using your chuck removal wedges or is this something different or also required?
    Dec 2009
    Hong Kong
    1
    Great idea
    從我的iPhone使用Tapatalk 發送
  1. hercus 260g sold $7000
    By dodge at4 in forum THE HERCUS AREA
    Last Post: 1st Oct 2018, 09:59 AM
  2. Hercus 9 Spindle Lock
    By Silversprings in forum THE HERCUS AREA
    Last Post: 23rd Dec 2017, 01:19 PM
  3. Hercus Craftsman Spindle Help!
    By anj909 in forum THE HERCUS AREA
    Last Post: 3rd Feb 2015, 07:54 PM
  4. HERCUS 260G
    By Jeff 8 in forum THE HERCUS AREA
    Last Post: 24th Jul 2014, 10:39 PM
  5. Hercus 260 spindle bearings available
    By jb1248 in forum THE HERCUS AREA
    Last Post: 14th Feb 2012, 02:05 PM
