Results 1 to 5 of 5
Thread: Hercus o mill base cabinet
28th Oct 2018, 07:36 PM #1Member
- May 2007
- NSW
- 51
So i went to the avenue of stripping out to inspect , clean and paint my mill. Did some mods on the cabinet stand, put a heavy duty low profile castor on the front, 2 rear wheels , 4 levelling legs. Cut out the front panel add a few weld here and there. Angle bar . Move the drain outlet of the tray to the back. Drawer for tooling, shelvings for other component, and coolant pump.
Sent from my SM-G930F using Tapatalk
28th Oct 2018, 10:33 PM #2Member: Blue and white apron brigade
- 7,188
Nice work so far but isn't the vertical axis screw going to mash into gear inside the top drawer ?
So far I'm really impressed with my mist cooler/lube system - so much so, that when/if I do up my mill I am seriously considering giving up on the pump and reservoir altogether so that the bottom is available for storage.
31st Oct 2018, 07:43 PM #3
Hi China eyes,
Welcome to the Metalwork Forum.
In case you were wondering, a new member with under 10 posts are moderated when the post a pic.
No one is picking on you, it just and bit of a protection built into the software.
BobL was able to respond as he has moderator status on the other side,but as far as I know no one else was able to view it or respond. Fixed now!
Sorry I was tad slow in approving your post.
31st Oct 2018, 08:05 PM #4Member
- May 2007
- NSW
- 51
All good thanks Grahame.
31st Oct 2018, 08:15 PM #5Member
- May 2007
- NSW
- 51
Thanks for pointing that out .. i did check it it wont hit the bottom board of the drawer but the back board will .. solution put the drawer on the bottom and put a shelf in there .. also was considering but doubtful about the mist coolant before but now hearing it works for you. Il go for that ..
Hercus o mill Vertical mill head lubrication
By china eyes in forum THE HERCUS AREAReplies: 0Last Post: 14th Oct 2018, 06:57 AM -
Hercus No3 T&CG base dimensions
By jcge in forum THE HERCUS AREAReplies: 19Last Post: 31st Aug 2016, 09:14 PM -
Hercus Mill
By wheelinround in forum THE HERCUS AREAReplies: 2Last Post: 7th Jul 2012, 11:35 AM -
Mill Cabinet
By Blu_Rock in forum METALWORK GENERALReplies: 6Last Post: 9th Apr 2012, 10:08 AM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM
