Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Jun 2016
    Sydney
    283
    are most modern lathes built with these types of screws instead of backlashy ones ?
    Modern commercial production-type machines - yes. Cheap little Chinese home lathes, no. The ball screws are more expensive.
    I have to agree that the acetal nut idea might be the best for you at this stage. Done exactly as described the nut can be a bit tight, but acetal is cheap enough that you can afford to experiment.
    Roger
  2. #17
    Nov 2007
    melbourne australia
    3,228
    By all means replace the nut, but don't expect it to eliminate the problem. I replaced my cross-slide nut and while it reduced the backlash, there's still quite a bit there. I need to reface the collar as described in the doc I posted above and also in the Hercus Textbook of Turning.
  3. #18
    Oct 2004
    Southern Highlands NSW
    1,894
    Both the nut and screw wear.
    Replacing nut only might reduce backlash, but wear on the screw is uneven so there will still be some play somewhere.
    Uneven screw wear could translate to inconsistent movement of the slide with respect to dial measurement, but it has to be pretty bad to matter I think.
    Installing a digital readout (DRO) overcomes screw wear, because it measures actual linear movement, unlike the dial.
    Have you leveled your lathe? That could help accuracy, you need an accurate level tool.
  4. #19
    Nov 2007
    melbourne australia
    3,228
    Inspired by this thread, I finally decided to remove the slop from the graduated collar on my 260. The setup is shown. Not shown in the pic is the compound rotated to 90 degrees to take the place of the cross-slide which is obviously out of action during the operation. Prior to this procedure I was just able to slip a 0.15mm feeler into the gap between the graduated collar and the fixed collar. You could see movement between the two when pushing and pulling on the compound. After the operation there is no visible movement between the two parts. However there is still quite a bit of backlash in the nut/screw interface. At a guess I'd say I have removed 10-20% of the backlash. I reckon it's a worthwhile fix. Took about 30 minutes. I used two Tally Ho cigarette papers for the shim.
    Watch out for the tiny woodruff key and the brass pad that goes under the locking screw when disassembling.
    Sorry about the PDFs. My iPhone has started taking photos in a new format (HEIC) after a recent iOS upgrade. The forum doesn't recognise HEIC and I couldn't work out how to convert to HEIC to JPEG, so PDF it is.
    Attached Files Attached Files
  5. #20
    Sep 2018
    South Australia
    88
    Sincere thanks to everyone for the comments, advice and effort.
    Nadroj, no, as yet I have not levelled the lathe. It is in my garage at the moment; it ultimately must move to my shed, so I will fit up the VFD while in the garage then break it all down, move to the shed, set up and level.
    Regarding the backlash, I think the plan will be to live with the lathe for awhile, then try replacing the nut and screw with new parts, then if still not happy try the skimming trick and maybe even a custom acetal nut. I love doing this sort of stuff so happy to try a few things.
    Again, thanks guys.
    Moz
  1. Tuning/Restoring of a Shaper Vice
    By Brobdingnagian in forum METALWORK GENERAL
    Last Post: 26th Mar 2013, 04:44 PM
  2. Backlash in Hercus 260 cross-slide
    By jack620 in forum THE HERCUS AREA
    Last Post: 4th Mar 2013, 06:19 PM
  3. Backlash adjusters
    Last Post: 27th Jun 2010, 10:38 PM
