Results 1 to 3 of 3
27th Aug 2018, 06:41 PM #1Member
- Apr 2018
Hercus 260/250G Chuck Removal Wedges
Hi all!
I have come up with a great idea which allows for very easy removal of chuck from a threaded spindle.
The part is made of plastic so it wont damage the threads and sits on the spindle behind the chuck which can be slammed on hard, and removed just as easily by removing the wedges.
No need for any spindle locks, back gears, etc.
All that is needed is a screwdriver.
I have so far run the lathe and the chuck has not come loose.
I currently have this equipt on my Hercus 260G and it works very well.
I can also make custom size wedges (eg for 9" spindle).
I would be asking $15 a set + postage (will have to get quote).
28th Aug 2018, 09:13 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I'm thinking - Do I really want to rely on a plastic component between the chuck and register face?
As there is inevitable play in the threads, and between the cylindrical register surfaces, a positive and rigid mating of the faces is important.
Also, there isn't that much thread length, which would be even less with your device?
A good solution to the stuck chuck problem would be very welcome.
30th Aug 2018, 04:21 PM #3Diamond Member
- Aug 2006
- 1,106
Are you able to get a photo up of it or maybe a video of it in action?
Lathe chuck removal shaft collar wedges
By ml018 in forum METALWORK GENERALReplies: 3Last Post: 27th Aug 2018, 06:35 PM -
Stuck chuck on Hercus 250G
By ml018 in forum THE HERCUS AREAReplies: 15Last Post: 14th Aug 2018, 07:55 AM -
Chuck removal device
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 2nd Jun 2013, 08:31 PM -
chuck removal ..spindle old
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 23rd Jan 2012, 05:23 PM -
Chuck removal
By Godzilla98 in forum THE HERCUS AREAReplies: 11Last Post: 30th May 2009, 06:19 PM
