Results 1 to 9 of 9
    Aug 2016
    Adelaide
    80
    Default Cross slide dome nut thread size
    Anyone know what the handle end of the cross slide screw thread is, one that the dome nut goes on? Circled in the image. I think I've damaged mine and hope I can get a standard die to clean it up.
    Feb 2012
    camden nsw
    2
    It’s 7/32 bsw
    Oct 2008
    Cairns, Q
    666
    If it is 7/32W you could run a 3/16W die over it ( same 14 TPI). I expect 3/16 dome nuts would be more readily available than 7/32.
    Frank.
    Feb 2012
    camden nsw
    2
    Quote Originally Posted by kynan View Post
    It’s 7/32 bsw
    That has been tried and stuffs up the thread completely
    Try taking the first one or two threads off the end of the spindle
    Alternative is lop the thread off drill and tap the end of the spindle 3/16 insert a bit of threaded rod. Use a standard 3/16 nut
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Find someone nearby with a lathe that can chase the thread for you?
    Sep 2011
    Ballarat
    65
    3,103
    You could use a thread file.
    Phil
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Pass on the chasing with a lathe, the thread is quite small and the chance of it all running true are?
    Jul 2016
    35
    1,522
    +1 for thread file. Only spin the work slowly though.
    Aug 2016
    Adelaide
    80
    Thanks for your suggestions, I managed to chase it in the lathe and carefully feeding by hand. It's not perfect but the nut goes on.
  1. 260 Compound and Cross Slide Micrometer stud thread???
    By ventureoverland in forum THE HERCUS AREA
    Last Post: 25th Nov 2014, 03:41 PM
  2. Cross slide reconditioning
    By argeng in forum METALWORK GENERAL
    Last Post: 5th Jan 2014, 07:46 PM
  3. Cross-slide play
    By jack620 in forum METALWORK GENERAL
    Last Post: 19th May 2012, 07:50 AM
  4. Cross Slide Nut
    By raypat in forum METALWORK GENERAL
    Last Post: 9th Dec 2011, 01:41 AM
  5. Cutting thread and nut on cross slide
    By B the B in forum THE HERCUS AREA
    Last Post: 18th Nov 2009, 01:36 AM
