Results 1 to 6 of 6
    Apr 2018
    Sydney
    64
    Default Largest size chuck for 260g?
    Hi!
    What would be the largest chuck the 260g could run?
    Would any damage be caused if the chuck was larger than it should?
    I know that the 4 Jaw chucks are around 6", would a 7.5" chuck be too big and heavy?
    Jul 2016
    35
    1,522
    I wouldn't concern myselfn with the weight so much as increasing the hangout from the spindle nose, does the G come with a camlock spindle?
    Apr 2018
    Sydney
    64
    Quote Originally Posted by caskwarrior View Post
    No, it seems like a standard threaded spindle like the Hercus 9 model.
    near Rockhampton
    6,216
    The issue with big chucks will be if you stick the jaws out beyond the chuck OD they might hit the bed.
    A bigger chuck may not necessarily mean you can hold bigger items. As bigger chucks have bigger jaws.
    Jul 2016
    35
    1,522
    Personally I would look for one of the thin 6" Pratt burnerds used on Myfords just because they are really thin, less stick out means less runout at the work as well as more space between centers.
    Oct 2004
    Southern Highlands NSW
    1,894
    The 260 brochure says swing over bed is 260mm, swing over cross slide is 159mm.
    Jordan
  1. HERCUS 260G
    By Jeff 8 in forum THE HERCUS AREA
    Last Post: 24th Jul 2014, 10:39 PM
  2. chuck weight size holding capacity ?
    By lather in forum METALWORK GENERAL
    Last Post: 21st Mar 2013, 10:52 PM
  3. What size chuck is best ?
    Last Post: 24th Oct 2011, 11:16 AM
  4. how to remove the chuck on a 260g
    By welder in forum THE HERCUS AREA
    Last Post: 25th Jul 2011, 10:41 AM
  5. Toolmaster Tool & Cutter Grinder Workhead Chuck size
    By steran50 in forum METALWORK GENERAL
    Last Post: 31st Jan 2011, 10:29 PM
