Results 1 to 13 of 13
28th Jun 2018, 04:53 PM #1New Member
- Jan 2017
- Toronto NSW
- 73
- 8
Model C Gearing for Metric Screwcutting
I am a self-taught novice on my late father's Model C. I am looking to turn a 1.25mm pitch thread for a carburetor jet in a veteran car. Two questions:
1. the chart on the lathe gear cover specifies a 27 stud gear but the Hercus book (p61 of the 1980 ed) specifies a stud gear of 24. Which is correct? To confuse matters further the book specifies a gear number for 1.0mm pitch which has been crossed out and 27 has been handwritten there (by my father I assume).
2. a 63/60 compound gear is specified - does the 63 run closest to the lathe or the 60? I'm finding it a bit hard to work out the diagrams!
Jeff
28th Jun 2018, 05:59 PM #2Most Valued Member
- 4,890
Is the lathe a 9" or 260?
29th Jun 2018, 12:49 PM #3Intermediate Member
- Apr 2016
- New South Wales
- 45
Viewers should be able to download that image (after logging in) and then zoom in on it for the details.
This is probably a different (earlier) edition of the Hercus Textbook of Turning, with instructions suitable for 9" Model B & C, and it relies on using the 127/100 transposing gear.
In FIG 3., on the screw pitch thread chart on the right, (of Figure 139, i.e. "FIG. 3 on Figure 139", getting a little complicated) the marking of the 18T side of the 72/18 compound gear is omitted (design error, or perhaps they did not copy the South Bend chart they are cloning this from fully/correctly). Although there is present the unidentified arrow pointing at the (obscured) 18T gear (obscured behind the 72).
It appears to me that on this set of diagrams the 127 tooth gear of the transposing pair 127/100 is mounted closest to the headstock. (But I am not sure whether my interpretation of the diagram is correct, nor am I sure if the diagram is correct.)
For 1.25 mm threads, according to the chart, and diagram - FIG 2. in particular - the 127T side of the transposing gear drives the 40T stud gear and the 80T screw gear drives the 100T side of the transposing gear.
29th Jun 2018, 08:39 PM #4Golden Member
- Nov 2010
- Gippsland Victoria
- 733
metric threads
There are various books and web sites that explain how to do the relevant calculation that gives the you the final TPI for any given gear train. If you google "metric thread imperial lathe 8tpi leadscrew calculator" you will find various discussions and calculators
Here is a page I found useful Metric Threading
Best thing I found was a free program written by a chap on this forum called Vernon, the program was called lathegears and you give it a list of all of your gears and then the tpi of your leadscrew and it it will calculate what gear trains will cut the the required thread - you can set a tolerance on the required thread ie +/- x.x% -its a very very good calculator. Link below ...
Lathe thread cutting change gear calculator [Archive] - Woodwork Forums
Bill
29th Jun 2018, 09:44 PM #5Most Valued Member
Bill, unfortunately the link comes up with an "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
29th Jun 2018, 09:54 PM #6Intermediate Member
- Apr 2016
- New South Wales
- 45
29th Jun 2018, 11:47 PM #7Most Valued Member
Just tried it again, it comes up with this page; Lathe thread cutting change gear calculator
I then click on "Here is the link http://www.woodworkforums.com/attach...1&d=1275121329"
Woodwork Forums
and I get "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
So what am I doing wrong??
29th Jun 2018, 11:47 PM #8Golden Member
- Nov 2010
- 733
Kryn,
More than one way to skin this cat ......Try this
Google "lathe thread cutting change gear calculator metalworkforums.com"
should be the first thing that google finds.
Problems might be due to archived tapatalk part of forums ... ? I dont know.
Bill
29th Jun 2018, 11:59 PM #9Most Valued Member
Thanks Bill, I still get the same message??
30th Jun 2018, 12:20 AM #10Golden Member
- Nov 2010
- 733
30th Jun 2018, 02:02 AM #11Intermediate Member
- Apr 2016
- New South Wales
- 45
Whoops, now I am infected.
Or more correctly I was infected all along ? The bird landing on its head corresponds to the file not being at the given location. "To be or not to be ?"
30th Jun 2018, 09:40 PM #12Golden Member
- Nov 2010
- 733
Try this
OK original download links seem broken.
See attached zip file and output example called output.pdf
I don't think I am breaking any copyrights by putting this up - see attached jpg file called about.jpg where permission is given to distribute the program.
I've tried this zip file on a laptop and it works - don't extract the files into the official windows programs folder because if you do that you wont get permission to input your own change wheels.
Its a terrific program and the chap deserves lotsa applause for writing it.
Bill
30th Jun 2018, 10:22 PM #13Most Valued Member
Thanks Bill, Managed to down load it.
Harrison M250 Metric Lathe - Imperial Screwcutting
By electrosteam in forum METALWORK GENERALReplies: 24Last Post: 17th Feb 2017, 06:20 PM -
mitutoyo Metric dial indicator model 513-404 come in box
By thorens in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 21st Mar 2016, 03:49 PM -
Metric Hercus Model A
By 1500king in forum THE HERCUS AREAReplies: 11Last Post: 21st Aug 2015, 09:32 AM -
are all threads in a model 9 non-metric?
By janvanruth in forum THE HERCUS AREAReplies: 13Last Post: 7th Aug 2014, 08:32 AM -
Proper gearing for 9 inch Hercus A Model
By downunderoz in forum METALWORK GENERALReplies: 24Last Post: 10th Jan 2011, 06:59 PM
