Results 1 to 3 of 3
    Sep 2008
    Riddells Creek, Vic.
    831
    Default Hercus Lathe motor Star to Delta conversion,
    A friend of mine picked up a 1960's roller bearing 9 inch lathe and was asking about a suitable single phase motor to allow it to be used at home on 240 volts. I suggested that it would be best to use the original motor and convert it to Delta and run it from a VFD. We found a small drive and Ebay and I got stuck into the conversion while we waited for the drive to arrive. These motor are well made and relatively easy to convert for 240 volt 3 phase operation.
    May 2011
    Murray Bridge S Aust.
    5,945
    Thanks for the pics, still not to sure about doing mine when it arrives, after I get the shed done.
    7,183
    The Hercus 9" lathe motors are indeed pretty accessible and have plenty of room to perform this task. I have done three of these and have one more on the bench to do.
    One of the hardest I was involved with was ABs Hercus tool and cutter grinder motor which was only 1/30th of a HP and had wires on it like fine hair. Another tricky one was a 1HP GMF motor from a Woodfast lathe . the star point was at the other end of the motor from the mains in-out connectors and there was absolutely zero room to get the star point connects back to the other end. In the end I had to go out through the motor end cap and back down outside the motor in a conduit to the main motor connection box. Anyway it works.
  1. Delta or Star
    By Auskart in forum METALWORK GENERAL
    Last Post: 21st Apr 2017, 05:26 PM
  2. ASEA motor Y to delta conversion.
    By da9jeff in forum ELECTRICALS
    Last Post: 27th Feb 2017, 11:36 AM
  3. Replies: 68
    Last Post: 22nd Jun 2015, 09:25 PM
  4. Replies: 68
  5. Star/Delta motor wiring
    By .RC. in forum METALWORK GENERAL
    Last Post: 3rd Mar 2012, 11:01 PM
