Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    7,182
    What eventually made it come out?
  2. #17
    Aug 2014
    Brisbane
    38
    Two hands on the hammer and swinging it like a meant it! One hit after a bit of heat from the front. I think I had been tapping a bit too lightly out of fear of wrecking it. Maybe even subconsciously...
    Speaking to one of the guys who worked at the school I purchased it from he said it hadn't been taken off while he worked there. Around 12 years. By the look of the vertical head and the fact that there were no collets or end mills and the fly cutter hadnt been used it may have never been taken off since 1980. At least the vertical head or accessories hadn't been used.
    Next step get a VFD or single phase motor to get it up and running!
    Thanks again all...
  1. Standard gear configuration for Hercus 9" and 260 lathes
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 23rd Aug 2017, 10:15 PM
  2. Replies: 7
    Last Post: 29th Sep 2015, 10:41 PM
  3. Hercus 9a standard accessories
    By kodiak in forum THE HERCUS AREA
    Last Post: 12th Jun 2015, 10:11 PM
  4. Removing standard lathe oil points
    By th62 in forum METALWORK GENERAL
    Last Post: 15th Sep 2013, 09:22 PM
  5. Removing Mill Motor
    By electrosteam in forum METALWORK GENERAL
    Last Post: 10th Jul 2010, 09:54 AM
