Results 1 to 4 of 4
    Sep 2017
    Seven Hills
    43
    Default Hercus Gear Rack ??
    More treasures from my dad's garage. Can someone tell me what these are and if they would be of use/value to anyone?
    There were 12 in a box stamped (maybe by dad) HERCUS 48F6P
    Many thanks
    John
    Nov 2008
    Perth WA
    6,459
    Hello John,
    Hercus made a number of stock racks. In the copy I have of their 1979 Transmission Equipment catalogue, they list a 48F6R (not P) rack. It was 48 1/4" long, 2" wide and 1 1/2" high. It had 92 teeth with a pressure angle of 20 degrees and was made from mild steel. They weren't specific about the grade of steel but the pinions they produced to suit the racks were made from 1045. Your racks may have been specially made or simply cut from longer lengths to suit some now unknown application.
    Bob.
    Sep 2017
    Seven Hills
    43
    Thanks Bob.
    I will probably put them up as freebies in market place in case someone can use them.
    Sep 2017
    Seven Hills
    43
    On closer inspection I believe it is 48F6R.
    Thanks. They are in market place now.
  1. Replies: 9
    Last Post: 20th Apr 2017, 09:01 AM
  2. Hercus 9 metric leadscrew gear
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 15th Sep 2016, 02:01 PM
  3. Hercus Model A Gear
    By anj909 in forum THE HERCUS AREA
    Last Post: 12th Feb 2015, 09:58 PM
  4. Hercus 127 tooth gear
    By bob colles in forum THE HERCUS AREA
    Last Post: 8th Jan 2011, 02:19 PM
  5. Hercus Collet rack
    By footz in forum THE HERCUS AREA
    Last Post: 30th Nov 2008, 07:31 PM
