Results 16 to 22 of 22
Thread: Standard parts for a 9" Model A
13th Mar 2018, 01:52 AM #16Intermediate Member
- Feb 2018
- Perth. Australia
- 63
- 27
Thanks for that Anorak Bob. Looks very interesting. I noticed mine has a McPhersons badge on the right hand side.
Well I guess I can call it mine now. I am now the proud owner of a Model A # 11461!
Picked it up Saturday and it is now happily residing in my shed!
It wasn't too bad to lift between 3 of us once we had removed the motor, tool post and tail stock as well as un bolting it from the base.
I still haven''t refitted the motor yet. Life has been a bit hectic the last week.
It didn't have a micrometer saddle stop unfortunately BobL.
I bought a new main drive belt today from Transeals in Welshpool.
A mate has offered me a 4" 4 jaw chuck for $50. Only problem is it is in Melbourne.
Thanks for all the tips and advice so far everyone. Keep them coming if you like.
13th Mar 2018, 10:21 AM #17Member: Blue and white apron brigade
- 7,182
Good work Mark.
While the motor is off you should have a look at the connections to see if it suited to a VFD.
13th Mar 2018, 04:45 PM #18Intermediate Member
- Feb 2018
- Perth. Australia
- 63
- 27
There's nothing very special about it BobL. It's just a single phase motor bolted to the original plate.
What are the advantages of a vfd?
13th Mar 2018, 04:52 PM #19Most Valued Member
If it’s single phase you can’t fit a VFD. Advantages of a VFD are speed control (fewer belt changes), faster deceleration (not too fast or your chuck will unscrew), jog and overspeed. I reckon it’s the second best addition to a lathe after a QCTP.
13th Mar 2018, 05:23 PM #20Member: Blue and white apron brigade
- 7,182
Chris has pretty well nailed it.
The ability to change speed without stopping the motor is probably for me the most useful feature.
If you use a chuck drawbar type holder you can also reverse the motor direction at the push of a VFD button - useful for unscrewing taps and dies.
13th Mar 2018, 07:44 PM #21Intermediate Member
- Feb 2018
- Perth. Australia
- 63
- 27
I've got the original 3 phase motor but don't have 3 phase power in my shed.
I might be stuck with the single phase for the time being.
13th Mar 2018, 08:02 PM #22Member: Blue and white apron brigade
- 7,182
Well that's another advantage of VFDs.
Up to about 4KW, some VFDs will convert 240V Single Phase to 240V 3Phase.
3Phase motors come in either of two connection modes.
Delta (∆) or Star (Y).
Some motors can be converted from 415V 3P Y to 240V 3P ∆ simply by changing connections inside the motor connection box.
That's why I suggested checking your motor connection box.
Some 3P motors are hardwired as 415V Y but can be converted to 240V ∆ so they can still run from a SP 240V VFD.
The conversion should really be performed by a motor rewinder but this can cost as much as a used motor with the right connections
3P motors hardwired as 415V ∆ cannot be converted to run on 240V since all they can be converted to is a "Y" connection and that will then make them an 830V motor.
In the Woodworkers forum there is a thread dedicated to VFDs and shows many example and explains some of the intricacies.
VFD install summaries
If you want to see a bunch of different machines running on VFDs, PM me to arrange a tour of my shed
Standard gear configuration for Hercus 9" and 260 lathes
By allterrain50 in forum THE HERCUS AREAReplies: 9Last Post: 23rd Aug 2017, 10:15 PM -
Fitting standard M/T 3 ER32 collet chuck into a Vertex 8" Rotary Table.
By pipeclay in forum METALWORK GENERALReplies: 9Last Post: 10th Jul 2015, 06:30 AM -
Phosphating parts "experiment"
By Pete F in forum METALWORK GENERALReplies: 43Last Post: 17th Nov 2014, 10:46 PM -
HERCUS MODEL A parts.
By yorkshire racer in forum THE HERCUS AREAReplies: 4Last Post: 18th Dec 2012, 05:21 AM -
Metal working rates for standard parts
By rppearso in forum METALWORK GENERALReplies: 33Last Post: 1st May 2009, 12:36 PM
