Results 1 to 5 of 5
    Oct 2011
    Sydney, NSW
    1,249
    Default Hercus Headstock Bearings
    Hi,
    I know this subject has been covered before but I can't find it using the search function so I'm asking again.
    I think my bearings in my Hercus 260 ATM have finally chucked it in. I'm going to strip the headstock sooner or later.
    If I do need to replace them, what are replacements, where do I get them et.c et.c.
    I think I read somewhere you can use standard trailer bearings?
    Ben.
    Oct 2011
    Sydney, NSW
    1,249
    I just seen on AMW you can get 9" bearings. Will these fit on a 260?
    hercus 9 headstock bearings--part Nos.825, 826
    Mal, do you sell 260 bearings?
    Oct 2011
    Sydney, NSW
    1,249
    Well played around with the headstock today. I noticed the spindle had some play in it (after reading a post by Pipeclay from some years back), I didn't measure the play - I could see it when I put pressure on the chuck. So I removed the take up nut and front and read bearing caps. I recorded the Timken numbers on the bearings, Rear main bearing (on left of HS as you look at it) 111622, Front main bearing (on right of HS) 18690.
    I decided not to take the spindle out and instead fitted everything back on. I tightened the take up nut right up so the spindle could not be moved by hand (and all play was removed) and then gradually loosened the take up nut until the spindle spun freely without any play. Once I was happy everything was checked for tightness and I ran the lathe at top speed for 5 minutes. There was no noticeable heat build up. I then started on completing a job I was on, monitoring the bearings. So far so good.
    I did some searching on ebay for replacement bearings:
    https://www.ebay.com.au/itm/TIMKEN-1...0AAOSwO7haS8sJ
    https://www.ebay.com.au/itm/11162-Ti...AAAOSwubFaVuUq
    https://www.ebay.com.au/itm/11162-3-...kAAOSwUd9aVuU0
    https://www.ebay.com.au/itm/TIMKEN-1...4AAOSwCMFaS83o
    https://www.ebay.com.au/itm/Wheel-Be...kAAOSw6b9Z4nOA
    Will any of these work? I haven't tried Australian suppliers yet but I don't reckon they'd be cheaper.
    near Rockhampton
    6,217
    Usually it is not the spindle bearings that are worn out causing issues.
    But anyway, you need a cup and cone for each end and apparently the cup is a flanged version so not as common
    //metalworkforums.com/showthread.php?t=143419
    Oct 2011
    Sydney, NSW
    1,249
    [QUOTE=.RC.;1931914]Usually it is not the spindle bearings that are worn out causing issues.
    I think your right. Tightening up the take up nut helped a lot. I also need to replace one V belt, thankfully not the spindle belt.
  1. Bronze headstock bearings.
    By flmath in forum THE HERCUS AREA
    Last Post: 15th Jun 2015, 12:14 PM
  2. Headstock bearings
    Last Post: 10th Dec 2014, 10:22 PM
  3. Herless Lathe Headstock Bearings
    By FTO_dude in forum METALWORK GENERAL
    Last Post: 8th Apr 2014, 08:12 PM
  4. Questions re Plain Headstock Bearings and Way wear
    By Vicroamer in forum THE HERCUS AREA
    Last Post: 2nd Nov 2011, 10:12 PM
  5. Hercus AR Headstock Bearings
    By Penpal in forum METALWORK GENERAL
    Last Post: 20th Nov 2008, 01:12 AM
