Results 1 to 5 of 5
Thread: Single phase motor for Hercus
1st Jan 2018, 06:05 PM #1Novice
- Oct 2009
- 17
A friend of mine just purchased an ATM 260, it did not come with a motor but did come with a pulley, he wants the easiest slip in/bolt on single phase motor, the pulley hole looks to be 14mm.
Thanks.
2nd Jan 2018, 12:35 AM #2Member: Blue and white apron brigade
- 7,183
Pulleys are dirt cheap so I would not be looking around too hard to try and match the motor to the existing pulley.
2nd Jan 2018, 06:40 AM #3Philomath in training
- 6,542
That's probably going to be a 1/3 or 1/2 hp 4 pole* from memory. Most motor rewinders sell FHP (Fractional Horse Power) motors as it is cheaper than rewinding them. The alternative is to contact Royce Cross Motors in Dudley Park. Their main business is selling motors. If you go to their web site Totally Enclosed 1425rpm Crompton Greaves General Purpose 240V Cap Start Motor - 020_Electric motors 240 Volt, 4 Pole - 1400rpm General - Product Detail - Royce Cross Agencies, on some pages like this one there is an additional information PDF which is a motor catalogue.
Look for a TEFC motor (Totally Enclosed Fan Cooled) so you don't suck dust in.
* 4 pole is around 1440rpm. I don't know whether that is the right speed so that you get the proper speeds as per the name plate
2nd Jan 2018, 01:54 PM #4Diamond Member
- Aug 2006
- 1,105
https://www.ebay.com.au/itm/0-37kw-0...sAAOSw3ydV4H-x - 14mm shaft
https://www.ebay.com.au/itm/0-75kw-1...UAAOSwzSRZ2deB - 19mm shaft
I think i'd be wanting to go the bigger motor though, pulleys are cheap. That place sells pulleys too, check out there other items. What size motor did these lathes originally come with?
2nd Jan 2018, 03:30 PM #5Senior Member
- Oct 2010
- NSW
- 177
[/QUOTE What size motor did these lathes originally come with?[/QUOTE]
3/4 HP
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Single phase Vs 3 phase motor ratings.
By KBs PensNmore in forum ELECTRICALSReplies: 56Last Post: 17th Sep 2017, 05:37 AM -
TECO Single Phase Motor for Hercus No.O
By Anorak Bob in forum THE HERCUS AREAReplies: 4Last Post: 23rd Jun 2015, 07:44 AM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
