Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 76
  1. #61
    Jul 2011
    Adelaide
    837
    where in Adelaide are you getting your grinding done? I only know of 1 slideway grinder in town and they defiantly wouldn't be cheap.
    Precision Grinding on a largish surface grinder. The ways on these machines are not that long.
  2. #62
    Jul 2011
    Adelaide
    837
    Default Its been a while
    I have this back together mechanically it has cleaned up quite well and doesnt have enough wear in it for me to want to get it re-machined yet. Here are a couple of photos.IMG_20180305_102516.jpgIMG_20180305_150251.jpgIMG_20180305_150301.jpg
    I should have the electrics done quite quickly but I am picking up a Colchester Bantam on Wednesday so it will probably be next week before I get the chance.
  3. #63
    Jul 2011
    Adelaide
    837
    [QUOTE=Anorak Bob;1928642]Hi Eric,
    While you have things apart there is one small modification that might prove useful. Drilling and tapping a hole in the table feed shaft casting will allow the fitting of a locking thumb wheel. When I acquired the No.1 from Peter Fou it had a lock consisting of a cap screw and a large knurled nut. I replaced it with the one piece wheel below. The table will still move slightly due to gear backlash but being able to stop it sliding with the twist of the wheel is a handy thing.
    Bob.
    QUOTE]
    Bob my hercus #1 came with the following item for locking the table. IMG_20180215_155155.jpgI think it is original as it looks like some off the knobs on the other attachments. It is made of brass.
  4. #64
    Nov 2008
    Perth WA
    6,458
    Thank you Eric,
    Not a bad idea making the thing from brass, When I photographed my knurled version it was, dishearteningly, brown with rust. Probably used that nasty 1214 thinking it was out of harm's way!
    Bob.
  5. #65
    May 2011
    Murray Bridge S Aust.
    5,942
    With the table locker being made from Brass, it wouldn't damage the table, as would a steel one. If you can't get some brass the correct size, fitting a brass screw, out of an electrical plug/socket will do the job. Drill a slightly smaller hole than the screw and tap in with a hammer.
  6. #66
    Nov 2008
    Perth WA
    6,458
    Something like this Kryn? //metalworkforums.com/f189/t200...42#post1928642
  7. #67
    May 2011
    5,942
    That's the one Bob, I forgot I'd seen it before. Dam CRAFT disease.
  8. #68
    Jul 2011
    Adelaide
    837
    Default Universal Head
    I am still working on this. I put new SKF bearings in the universal head. Some time ago @MichaelG gave me some felt for use in the dust seals on the grinding shaft, luckily it was also perfect for the dust seal on the end of the head.
  9. #69
    Jul 2011
    Adelaide
    837
    IMG_20180626_134953.jpgIMG_20180626_134940.jpgIMG_20180626_134942.jpgIMG_20180626_134927.jpgA bit more rust removal and cleaning up. I feel like this is on the home stretch now.
  10. #70
    May 2011
    5,942
    Which of the 2 is this one Eric, yours or mine? Nice cleanup and assembly work.
  11. #71
    Jul 2011
    Adelaide
    837
    It still mine. Yours is the 3A model (different Z mechanism) and is dirty and as rusty as this one was to begin with other than the bits that have been re-machined.
  12. #72
    May 2011
    5,942
    Just thought you were being really generous to an old gery atric
  13. #73
    Jul 2011
    Adelaide
    837
    Default Back to the 3A.
    For Kryn and others following this thread. You might remember I started with a Hercus #3A T&C grinder and had the ballways reground and a new lead screw for the infeed and a new V belt pulley made before being distracted by a much younger model Hercus #1 with the better designed vertical axis. Well I promised Kryn he could buy this so I am putting it back together for a trip to Murray Bridge. Here is progress so far.
  14. #74
    Jul 2011
    Adelaide
    837
    IMG_20180728_150504.jpgIMG_20180728_150445.jpgIMG_20180728_150425.jpgIMG_20180728_150200.jpgSo this pile of bits is going to Kryn if the senile old bugger hasn't forgotten he asked for it.
  15. #75
    May 2011
    5,942
    I represent that remark!!! I know I asked for it, and I'm happy about it.
    Looking forward to getting it in the shed.
  1. Hercus Tool and Cutter Grinder
    By Geoff123 in forum THE HERCUS AREA
    Last Post: 28th May 2015, 09:43 AM
  2. Hercus Tool & Cutter Grinder For Sale in Queensland
    By A J in WA in forum THE HERCUS AREA
    Last Post: 7th Jan 2014, 11:10 PM
  3. Hercus No.1 Universal Tool & Cutter grinder
    Last Post: 3rd Jan 2014, 01:48 PM
  4. hercus No.1 tool and cutter grinder
    By allterrain50 in forum THE HERCUS AREA
    Last Post: 29th May 2011, 07:10 PM
  5. Hercus tool & cutter grinder
    By steran50 in forum METALWORK GENERAL
    Last Post: 23rd May 2011, 08:20 PM
