Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Jun 2017
    Bellevue
    12
    As mentioned in my last post I said I would share photos of the (almost) completed restoration of my 1958 Hercus Lathe.
    I still have to wait a bit before I can start doing some turning as I have an electrician coming to wire in the 1/2HP single phase motor and install a new start/stop switch and make safe the general wiring in the garage.
    Its been a great challenge and I have really enjoyed the time spent working on it and getting to know how things tick.
    I am sure you've spotted the obvious mistake with the red and black colouring on the gear box plate! I gave it a thorough cleaning but there appeared to be some engrained black (paint?) in one particular area where the red was supposed to be and despite my determined effort I couldn't shift it. This black showed through the new red paint and I wasn't happy with it. Hence the reversal of the colours.
    1958 Hercus Lathe - Headstock.jpg1958 Hercus Lathe - Saddle and tailstock.jpg1958 Hercus Lathe - Inside gear cover.jpg
  2. #17
    Jun 2017
    Bellevue
    12
    I have finally got my Hercus, and my garage, wired up by an electrician last week. My first project was to turn up a replacement saddle locking screw with a little modification. I don't always put the spanner down in the same place so I thought i would add a little tommy bar to it. It works very well. It was my first shot at single point threading on this machine and I wasn't disappointed with the Hercus' performance. Very easy to use and a pleasure to work on.
    Apologies for the orientation of the second photo it was the correct way round on file!
    Newly wired up motor with safety trip switch and fwd rev switches .jpgSaddle lock - no spanner.jpg
  3. #18
    Apr 2012
    16
    Very nice, has come up great.
    Are those belt guards standard for Hercus? I think my 9a is about 10 years earlier and doesn't have them.
  4. #19
    Jun 2017
    Bellevue
    12
    Hi Joe88.
    Unfortunately I dont have the answer to your question. The motor belt guard appears to be reasonably well made but not quite as well finished as the rest of the machine. its also made from sheet steel but the spindle belt guard is aluminium and I though they may have both been the same. Maybe others in the forum can assist?
    Regards Vince
    Quote Originally Posted by joe88 View Post
  5. #20
    Aug 2015
    Adelaide
    239
    Nice job on the the restoration there Vince.
    The belt guard on the headstock is a standard unit as I have the same one on one of my wrecked lathes. I think that a lot of guards were retro-fitted in the later years especially people making metal guards for the motor pulleys as I have seen a few home made jobs of those.
    Enjoy using the lathe although it seems a shame to use them after all of that work goes into them.
  6. #21
    Jun 2017
    Bellevue
    12
    Hi Tinkerer77,
    Thanks for the appreciative comments and the response to the guards.
    As for your comment on 'it being a shame to use it after all of the work that goes into them', even after a short space of time that gleam of new paint, especially around the headstock and top of the saddle, is now taking on the hue of dirty oil from using the lathe! its a real shame to see them lose the shine but like most users it would be more of a shame not to use them!
    Vince.
    Quote Originally Posted by Tinkerer77 View Post
  1. Replies: 11
    Last Post: 29th Apr 2017, 05:59 PM
  2. AR Restoration
    By Tinkerer77 in forum THE HERCUS AREA
    Last Post: 16th May 2016, 02:10 PM
  3. Hercus Model ARM restoration
    By country kid in forum THE HERCUS AREA
    Last Post: 21st Aug 2015, 09:46 AM
  4. Hercus 9" restoration, a few Questions
    By VK6BHY in forum THE HERCUS AREA
    Last Post: 28th Jul 2012, 04:11 PM
  5. 260 restoration
    By Finnowa in forum THE HERCUS AREA
    Last Post: 18th Oct 2010, 12:14 AM
