Results 1 to 12 of 12
    Apr 2016
    New South Wales
    45
    Default A Youtube series: The adventures of WELDA, saga of the 1970s Hercus 9A restoration
    I had a search in the forum to see if anyone had mentioned the existence of this series on Youtube before, but I did not find any records of it in forum posts, which is not what I would have expected. I may have been searching incorrectly, in which case, if it has been mentioned before, my apologies for repeating the information to the forum redundantly.
    The featured Hercus had taper roller bearings, beware the difference between Timken 18620 and Timken 18620B bearings (?)
    I do not know if the links (see below, there are a lot episodes, but they are commercial free) will work or not until I try it.
    There are parts / episodes missing, mostly the missing parts were either not recorded in the first place, or the camera / iphone killed itself, or the hard disk of WELDA (aka Greg ?) crashed.
    #WELDA Day 1 - Lathe Restoration
    #WELDA Day 2 - Lathe resto - surface prep tools and techniques
    #WELDA Day 3 - Lathe Resto - teardown
    #WELDA Day 4 - Lathe Resto - Cleaning Solvents
    #WELDA Day 6 - Lathe Resto - Prepare the lathe bed
    #WELDA Day 7 - Lathe Resto - painting the bed
    #WELDA Day 8 - Lathe Resto - Spindle Bearings
    #WELDA Day 9 - Lathe Resto - Wash Scrub Clean
    #WELDA Day 10 - Lathe Resto - Bits & Pieces
    #WELDA Day 11 - Lathe Restoration - Strip the Apron
    #WELDA Day 12 - Lathe Restoration - Strip the gearbox
    #WELDA Day 13 - Lathe Restoration - Paint Stripping
    #WELDA Day 14 - Lathe Restoration - Bits & Pieces #2
    #WELDA Day 15 - Lathe Restoration - Prepping for more paint
    #WELDA Day 16 - Lathe Resto - Body Filler
    #WELDA Day 17 - Lathe Restoration - Fill Sand Paint
    #WELDA Day 18 - Lathe Restoration - The paint prep never ends!
    #WELDA Day 25 - Lathe Restoration - Reassembly #1
    #WELDA Day 29 - Lathe Restoration - Installing headstock bearings
    #WELDA Day 30 - Lathe Restoration - Reassembly #2
    #WELDA Day 31 - Lathe Resto - (Almost) final assembly
    #WELDA Lathe Restoration - finished! And Lessons Learned.
    And now for a message from our sponsors...
    Donald
    Jan 2012
    Sydney
    8
    Quote Originally Posted by Donaldo View Post
    Donald
    The links dont seem to have come through... (to me at least!)
    Sent from my SM-G930F using Tapatalk
    Jan 2012
    Sydney
    8
    Sorry, didnt mean to quote the whole text again... 😞
    Dec 2008
    Yarra Valley Vic oz
    1,995
    Links work for me.
    Nov 2006
    Heidelberg, Victoria
    79
    2,074
    What a terrific series, well worth a watch.
    Ken
    Mar 2012
    adelaide
    91
    I had a quick look through some of the video , was there a survey done on the machine ? As all I can see that he has done is repainted a lathe and replaced the spindle bearing, and is there a post "rebuild" accuracy check ?
    Apr 2016
    New South Wales
    45
    I would like to see two extra, digitally remastered, director's cut episodes, namely:
    Day X, Removal of headstock from bed
    Day Z, Re-assembly of headstock on bed
    Aug 2015
    Adelaide
    240
    The removal of the headstock is quite easy, it is just clamped down with 2 bolts, you can get to the front end with a socket and short extension and the back with a spanner, refitting is easy enough and you have to make sure you line up the reverse shaft gear with the rest of the rest of the gear train and clamp it back down, the headstock will go back in to it's original position on the bed as it guided by the V way but this is where cleanliness is critical. Replacing the bearings is not an overly fun job as getting the cups out is quite painful as there is not a lot of room to knock them out. Resetting of the spindle is a bit tricky as well, the Textbook of Turning says that the spindle should have a preload 1.5 to 2 inch pounds of force to keep the spindle moving after it has been started from rest, I use a digital fish scale (real precision I know) and the scales do not have Inch pounds on them so you need to convert that to Ounces of force which is 6.267 which is 1 Inch pound so times that by 1.5 = 9.400 Ounces to 2 Inch pounds = 12.534 Ounces measured off a 2" diameter bar in the chuck and that is a little bit of messing around to get the right feel of it.
    Aug 2015
    Adelaide
    240
    I thought that I would put up a photo of the gear train alignment when the headstock is reset into it's position, the gearbox or leadscrew bracket (front bearing) need to be on the machine with the change gear bracket and the idler gear or gears if it is a B or C model lined up and then the headstock is put into it's correct alignment and tightened up.
    near Rockhampton
    6,218
    B means flanged cup in Timken speak.
    Aug 2015
    Adelaide
    240
    I was referring to the B and C model lathes with the lead screw bearing at the headstock end instead of the model A gearbox and not the taper bearings.
    Apr 2016
    New South Wales
    45
    Quote Originally Posted by Tinkerer77 View Post
    And.the.part.number.on.the.taper.bearing.is.usually.not.the.same.as.the.serial.number.on.the.lathe.bed.(unless.you.are.that.one.lucky.proud.Hercus.owner.with.the.magical.lathe.with.the.same."serial".number.on.lathe.bed,tailstock,gearbox.and.taper.bearing).
    Hopefully.this.unique.and.highly.sought.after.machine.is.still.out.there.somewhere...
  1. Adventures with cast iron - a wood plane.
    Last Post: 30th Jul 2023, 11:53 AM
  2. We are now in the 1970s
    By clear out in forum WELDING
    Last Post: 17th Aug 2016, 05:02 PM
  3. Hercus Model ARM restoration
    By country kid in forum THE HERCUS AREA
    Last Post: 21st Aug 2015, 09:46 AM
  4. Hercus 9" restoration, a few Questions
    By VK6BHY in forum THE HERCUS AREA
    Last Post: 28th Jul 2012, 04:11 PM
