Results 1 to 9 of 9
2nd Feb 2017, 08:22 PM #1Intermediate Member
- Jan 2017
- AU
- 30
Hercus ARM and No.0 Mill recommissioning.
Hi all, thought I'd start a thread about the 2 machines I've recently purchased. The first is a Hercus ARM:
The second being a Hercus No.0 mill:
Both machines are ex highschool and to me atleast, look in good condition.
So current progress is that I have cleaned both machines and removed most of the 3 phase gear. The plan is to convert the ARM to single phase and the No.0 to vfd, if I can get the original motor wired in delta.
The lathe needs a tool post (either a generic qctp or one from amh). The mill is pretty well ready to go once I sort out the motor.
I'll try to keep this thread updated and hopefully some hercus gurus can answer some of my questions along the way. Im a aircraft tech by trade so the electricals and what tooling I need is all new to me.
Jeff
Sent from my SM-G930F using Tapatalk
2nd Feb 2017, 09:14 PM #2New Member
- Jan 2012
- 8
Looks like a great score!
If I were you I would consider finding a VFD for the lathe as well... it would be far more user-friendly than changing belts...
You also have the benefit of retaining reverse. (Easier than finding a reversible/switchable single phase motor)
Alternatively, get a quote for installing a 3 phase circuit! Plug and play! 😉
2nd Feb 2017, 09:15 PM #3Senior Member
- Jan 2012
- Hinchinbrook
- 112
OMG! 1st thing to do is re-paint those covers and guards!
Nice score. Check your TS serial # against the bed #. Its not uncommon for school, (or anywhere really that has multiple same machines) for parts to be interchanged.
Is that a couple of collets in the tray on the lathe? Did you get any other accessories? Outside jaws for the 3 jaw. 4 jaw chuck. Faceplate?
Cheers Phil
2nd Feb 2017, 09:36 PM #4Intermediate Member
- Jan 2017
- AU
- 30
The collets are for the mill (took a bit to figure out as ive never used collets before) havent seen them on ebay, the end mills that came with it have a thread on the end that screws into the collet.
Lathe only came with a live center, also need to source a chuck key (dad has a seig c6 which probably has a metric key that doesnt fit).
The mill came with the dividing head and tail stock, a horizontal driveshaft with a cutter fitted, and the standard table vice.
2nd Feb 2017, 10:38 PM #5New Member
- Jan 2012
- 8
2nd Feb 2017, 10:48 PM #6Intermediate Member
- Jan 2017
- AU
- 30
Ill measure it up on the weekend. Very keen to give all the bits a workout
4th Feb 2017, 01:08 AM #7Banned
- Aug 2015
- QLD
- 735
Looks like yer got the tools to make yer own key.
The stock Hercus lathe tool post would be an easy make in the mill as well.
For something flash, I'm sold on them Aloris...
- Aloris Tool Posts | Quick Change Tool Post Originator
Or off ebay, Ajax can supply cheap Aloris tool holder copies:
Great deals from Ajax Industries | eBay stores
4th Feb 2017, 08:04 PM #8Intermediate Member
- Jan 2017
- AU
- 30
Pics of the mill and the lathe motors (in order):
So looks like the mill can be wired for delta but im not sure about the lathe.
26th Feb 2017, 03:19 PM #9Intermediate Member
- Jan 2017
- AU
- 30
Mill motor now looks like this:
Lathe is still a work in progress.
Hercus No.0 mill
By neksmerj in forum THE HERCUS AREAReplies: 6Last Post: 7th Jun 2015, 10:41 AM -
Hercus OLM Mill
By lyleman in forum THE HERCUS AREAReplies: 2Last Post: 7th Mar 2015, 06:43 PM -
Hercus O Mill
By bwal74 in forum THE HERCUS AREAReplies: 10Last Post: 6th Jan 2013, 03:52 PM -
Arboga EM825 mill vs Hercus model 0 mill?
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 14th May 2011, 03:16 PM -
Hercus Mill
By PBrown in forum METALWORK GENERALReplies: 5Last Post: 6th May 2009, 01:04 AM
