Results 1 to 8 of 8
Thread: My 1966 Hercus 9in C
7th May 2016, 08:28 AM #1New Member
- May 2016
- Penrith
- 6
Hi all,
I inherited this Hercus lathe from my fishing buddy. I'm new to this, Mal Has helped a lot. Thanks Mal for all your help understanding all the parts. I will get my head around it one day. Lathe has a placard on it. DEPT NSW TAFE.
Cheers Tommo
7th May 2016, 09:00 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
It looks nice, Tommo.
Did you get the change gears too?
You probably know already, but don't try to cut the shaft with that much supported overhang.
My rule of thumb is 3x the diameter as a maximum length sticking out from the chuck, otherwise use the tailstock or steady for extra support.
Jordan
7th May 2016, 09:11 AM #3New Member
- May 2016
- Penrith
- 6
Hi Jordan,
That was only out for display, I was teaching myself how to dial in the 4 jaw chuck.
Cheers Tommo
7th May 2016, 09:30 AM #4New Member
- May 2016
- Penrith
- 6
Jordan nothing extra as is, it's in pretty good nick for its age considering it started life at NSW TAFE.
Thanks Tommo
7th May 2016, 09:34 AM #5Most Valued Member
- 4,887
We're setting zero at both ends or only one on your bar?
7th May 2016, 09:42 AM #6New Member
- May 2016
- Penrith
- 6
Close to the chuck, I watched some YouTube videos, Cracked on for 2 hours walked away watched another, had another shot done in 5 min. Now I find it a little bit easier.
Cheers Tommo
7th May 2016, 11:33 AM #7Most Valued Member
- 4,887
When setting a long piece like that it needs to be set at both ends.
It would be a very rare occasion when you can get the bar running true over that length without touching the out board end.
In quite a few cases you would end up taping the out board end with a soft hammer to get it true, ( would pull the indicator plunger off the job when taping.)
If the bar is not round ( may have a high spot ) then either 3 zeros are ok or 2 zeros and the other 2 readings can be the same ,EG 2 zeros and 2 .003" or something similar, if you try to get all zeros with a bar that is not round you will be chasing it forever.
7th May 2016, 11:14 PM #8Most Valued Member
- 5,942
Welcome to a top Forum Tommo.
By Ozymacca in forum THE HERCUS AREAReplies: 0Last Post: 7th May 2016, 08:10 AM -
Hercus 9" vs hercus 260 ????????
By bitza500 in forum THE HERCUS AREAReplies: 1Last Post: 26th Jun 2009, 10:50 PM -
Hercus parts on Ebay from Hercus
By bollie7 in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2008, 02:59 PM
