Results 1 to 6 of 6
30th Oct 2015, 01:58 PM #1Novice
- Oct 2015
- 17
removing pin from worm
Hi All,
[ solved the apron wheel pin ]
The key in the worm looks to be held in with a pin. Or the pin is a part of the key. Do I need to support the worm in some way before knocking the pin out?
Justin.Last edited by Justin Wright; 30th Oct 2015 at 05:29 PM. Reason: new problem
3rd Nov 2015, 11:54 PM #2Intermediate Member
- Dec 2011
- Dunsborough WA
- 28
Justin,
A while back I fully restored a Model a and took lots of images, will have a photo of how the pin is installed if that will help.
Please let me know which part.
4th Nov 2015, 11:43 AM #3Novice
- Oct 2015
- 17
Michael,
Here is the bit.
I have tried tapping the pin lightly, but I am concerned that hitting it hard will spread the top or the pin, or stress the worm sleeve or damage the worm itself.
The photos show that the key itself will come out, but I assume the pin is holding it in. I can see the pin on the other side of the key.
4th Nov 2015, 01:28 PM #4Intermediate Member
- Dec 2011
- Dunsborough WA
- 28
Justin,
Have found a few images that will help you.
As you will be able to see the key is held in place with the pin.
Hope this helps, have lots of images that I took as I restored the lathe, unfortunately I still have not got to use the lathe, moved towns and built a house, I still have to do the electrics and then I will be able to use
11th Nov 2015, 12:43 PM #5Novice
- Oct 2015
- 17
Michael,
Thanks for the images. The apron is now apart and being stripped!
12th Nov 2015, 10:26 PM #6Intermediate Member
- Dec 2011
- Dunsborough WA
- 28
Justin,
Great hope the images helped.
I noticed a old thread that mentioned how to remove the pin, using a G clamp, search for Removing the worm drive from a power feed apron
The link should be near the bottom of this page under similar threads.
Re your other post about the paint layers, had a look through my images before cleaning and from what I can remember the filler was a light grey and the cast metal was a dark colour except where it had been machined.
As my Lathe was light green I re painted with Killrust spray pack, colourbond Wilderness, was that close to original.
Good luck with the restoration.
Brass Handwheel?
By Timless Timber in forum METALWORK GENERALReplies: 40Last Post: 9th Mar 2014, 12:42 AM -
Handwheel Driven Leadscrew
By Jors in forum METALWORK GENERALReplies: 7Last Post: 27th Dec 2012, 08:50 PM -
By BrassMonkey in forum THE HERCUS AREAReplies: 2Last Post: 19th Dec 2010, 07:21 PM -
Removing the apron, saddle and gearbox from a 260 ATM
By BrassMonkey in forum THE HERCUS AREAReplies: 0Last Post: 22nd Nov 2010, 04:34 PM -
Removing cast handwheel from steel shaft
By billrule in forum METALWORK GENERALReplies: 14Last Post: 10th Oct 2009, 08:24 PM
