Results 1 to 8 of 8
22nd Sep 2015, 09:46 AM #1Intermediate Member
- Aug 2014
- Brisbane
- 38
Hercus 260 Standard Attachments as at 1988ish and their Specifications / Sizes
Hi All,
I found this with the papers that I got with my lathe. It is a sales brochure that lists all of the standard attachments and their specifications. It may be of interest to someone and hopefully helps to answer some questions that you may have. I am guessing its 1988 as some other documents that I have are dated 1988.
25th Sep 2015, 12:27 PM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Thanks Noob,
I already have it, but yours is much smaller file size, and better resolution.
Jordan
29th Sep 2015, 09:04 AM #3
Thanks, very interesting.
29th Sep 2015, 10:08 AM #4Banned
- Aug 2015
- QLD
- 735
Pg 7. "Cup type drive plate" New one on me. What were those used for ?
Pg 8. "Low voltage light 32 volts" I know a lot of rural home power units were 32volt in the day, though why on a 1980's lathe? Were 32 volt a factory standard perhaps?
29th Sep 2015, 04:24 PM #5Mechanical Butcher
- Oct 2004
- 1,898
29th Sep 2015, 06:37 PM #6Banned
- Aug 2015
- QLD
- 735
29th Sep 2015, 06:38 PM #7Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
These "Cup Type" Drive Plates were used at Sydney Tech (Ultimo) on lathes during the 1950s 1960s & as Jordan "Nadroj" outlined were for safety reasons.
Bruce
29th Sep 2015, 10:41 PM #8Senior Member
- 112
Pg 8. "Low voltage light 32 volts" I know a lot of rural home power units were 32volt in the day, though why on a 1980's lathe? Were 32 volt a factory standard perhaps?[/QUOTE]
32 volts was an industry standard in that era for lead lights and other lights exposed to possible breakage in situ where safety was an issue. Globes of 60W and 100W were readily available of reinforced filament construction (RC). The outlet socket for 32 volts has two flat pins across the centre but at right angles to each other. See Clipsal Cat#405/32 or HPM Cat#57 described as "2-pin Flat, 'T' polarised base, 15 amp., 32 volts". Corresponding plugs were, of course, available from both companies.
Chas.
Standard gear configuration for Hercus 9" and 260 lathes
By allterrain50 in forum THE HERCUS AREAReplies: 9Last Post: 23rd Aug 2017, 10:15 PM -
Hercus collet attachments
By sgtfoxhound in forum THE HERCUS AREAReplies: 0Last Post: 21st Jul 2015, 03:34 PM -
Hercus 9a standard accessories
By kodiak in forum THE HERCUS AREAReplies: 10Last Post: 12th Jun 2015, 10:11 PM -
Specifications
By Tiptoeturtle in forum THE HERCUS AREAReplies: 3Last Post: 9th Jan 2013, 03:34 PM -
MIG Welder SPecifications
By kitcho in forum WELDINGReplies: 0Last Post: 11th Jan 2007, 11:01 AM
