Results 1 to 5 of 5
23rd Nov 2014, 08:38 PM #1
260 Compound and Cross Slide Micrometer stud thread???
Evening all,
Today I decided that I'd make a couple of thumb screws for my 260 so that I could easily zero my cross-slide and compound dials, replacing the grub screws that are barely long enough - Only problem is I can't determine the thread.
I know the diameter of the stud that fits is 180 thou (4.57mm) and its a 24TPI thread.
The closest Ive got so far is that it could be:
- No10 UNC
- 3/16 BSW (But it looks like a 60 degree and not a 55 degree as BSW should be)
I have a No10 UNC die but that doesn't seem to fit - I turned the shaft down to that of the stud that fits and then ran the die down it.
Could anyone confirm what it actually is?
Jon
25th Nov 2014, 06:01 AM #2
Anybody got any ideas? My google searching drew a blank.
Thx
Jon
25th Nov 2014, 07:12 AM #3Most Valued Member
- 4,887
Your screw OD doesn't conform to either of the threads you mention, ( unc .190" / bsw .1875" ) may be due to wear.
The different angle shouldn't present any great concern, you may have to run a tap through the dial, 10/24 unc would be my 1st choice.
25th Nov 2014, 10:11 AM #4
Thanks Pipeclay - Running tap down the dial . I'll give it a go - hopefully the thread is simply blocked with years of crud and once it starts it'll be fine.
By turning my new shaft down to the same diameter as the screw that came out and then running the tap down it, I thought I should be OK - assuming I'd picked the right thread!
I'll have another look tonight and see how I go.
Thx
J
25th Nov 2014, 03:41 PM #5Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Hercus 260 Cross & Compound Thread
I machined mine to .187" dia & Screwcut to 3/16" - 24 tpi BSW thread form & they fitted fine.
The larger dia. heads of the Screws are Knurled.
These have proved to be very convenient locking screws.
regards
Bruce
Cross slide scraping
By Stustoys in forum METALWORK GENERALReplies: 358Last Post: 13th Jan 2013, 10:08 PM -
Cross-slide play
By jack620 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2012, 07:50 AM -
Cross Slide Nut
By raypat in forum METALWORK GENERALReplies: 19Last Post: 9th Dec 2011, 01:41 AM -
Cutting thread and nut on cross slide
By B the B in forum THE HERCUS AREAReplies: 13Last Post: 18th Nov 2009, 01:36 AM
