Results 1 to 8 of 8
Thread: No.3 tool and cutter grinder
4th Jun 2014, 08:44 PM #1australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
At last I got around to doing something about the T & C grinder I picked up a while back. All was going well till I came to the rack gear under the table, guess what no gear. Does anyone happen to have one I can buy or one I can get a loan of to make a copy.P1010678.JPGP1010679.JPG
6th Jun 2014, 07:32 PM #2australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Almost ready to fire up, still need the gear that drives the rack and have to fabricate a few pieces, but that shouldn't take long.
7th Jun 2014, 07:09 PM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
I also have a resto project No.3, and can lend you the missing gear.
The bronze helical gear measures ~36mm across the tips of opposing teeth, which are all a bit furry on mine, and seem to be worn thin.
The bore is 5/8" with a 3/16" keyway which is about 1/16" deep.
Length is 3/4".
The angle of the 16 teeth appears to be at 15 degrees.
Jordan
7th Jun 2014, 09:36 PM #4australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
rack gear
Thanks Jordan,
I think I can get by with what you have given me in your reply. I've done a quick calculation which suggests its 12dp( I would have expected 14dp) with a one tooth adjustment, quite standard for a lot of the Hercus apron and gearbox gears. I'll check the rack agrees with that and get back to you.
regards Mal
24th Jun 2014, 03:57 PM #5australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
all good
Hi Jordan,
Thankyou, I now have a gear on the machine. All good.
Mal
24th Jun 2014, 06:33 PM #6Mechanical Butcher
- Oct 2004
- 1,898
Good one Mal.
Will you be offering to make them to sell? Emma Chisset?
Jordan
24th Jun 2014, 09:48 PM #7australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
for sale?
Hi Jordan,
Not at the moment, I would have to have a batch professionally hobbed ,although homemade gear is good enough for me and works quite well it is not of a quality fit to sell. A bit beyond my finances with what I've got currently in the works. Concentrating on the crosslides and tailstock quills at the moment. I was planning on doing the "O" mill stuff next because of the similarity to the lathe components.
The Hercus tool and cutter grinders don't seem to be very nurmerous and remaking the parts is probably not a viable option at this time.
Mal
25th Jun 2014, 12:32 AM #8Mechanical Butcher
- Oct 2004
- 1,898
Very understandable, Mal.
I was just curious, even though my gear is still serviceable as is.
Jordan
Another Tool And Cutter Grinder
By Anorak Bob in forum METALWORK GENERALReplies: 26Last Post: 13th Nov 2013, 12:15 PM -
Tool and Cutter Grinder
By Jors in forum METALWORK GENERALReplies: 13Last Post: 17th Oct 2012, 07:32 AM -
tool an cutter grinder maybe???????
By tanii51 in forum METALWORK GENERALReplies: 2Last Post: 1st Jul 2011, 09:30 AM -
Tool & Cutter Grinder
By graemet in forum METALWORK GENERALReplies: 14Last Post: 20th Nov 2009, 08:27 AM
