Page 5 of 13 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 184
  1. #61
    Nov 2018
    Okanagan Falls
    8
    I'd like to add a single phase VFD to my Hercus, since the lowest speeds are still too high for some jobs.Also want to add a quick change tool post, the Hercus post doesn't accept my larger bits in it. Going to check with KMS in Kelowna or, get one online from Busy-Bee in New West.
    https://www.asaindustry.com/store/p4...-_Compact.html
    Probably need to upgrade the motor too.
  2. #62
    Jan 2009
    Holbrook, NSW
    73
    490
    Quote Originally Posted by Mirage257 View Post
    How slow are you trying to go.
  3. #63
    Nov 2018
    Okanagan Falls
    8
    60-80 or around that.
  4. #64
    Jan 2009
    Holbrook, NSW
    73
    490
    you should be able to get that in back gear mode.
  5. #65
    Nov 2018
    Okanagan Falls
    8
    I have the P type drive with single speed motor, 4 step V belt pulleys. The driving motor has a single v pulley. Could find or machine the two groove pulley the motor I have but finding right size large two groove pulley would be more difficult. I would prefer electronically controlled system though.
    Found this on Amazon that could work with 3 phase motor. https://www.amazon.com/dp/B07D76365G/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07D76365G&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=f0dedbe2-13c8-4136-a746-4398ed93cf0f&pd_rd_wg=c8Ihv&pf_rd_r=9N3JFTZGJMY8GMHVB12C&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&pd_rd_w=5n0vk&pf_rd_i=desktop-dp-sims&pd_rd_r=113f9c95-f481-11e8-8944-4f5e302c649a
    I could use these lathes when I was still working.
  6. #66
    Jul 2012
    Griffith NSW
    435
    Gday Mal, feel free to add mine too. ATM 19975. In very nice condition, looks like it was barely used and has come out of Tumbarumba HS. It came as a pair, my mate bought the other lathe there, a DGM 19976. His had been dropped on its face, but Ive helped him repair the various bits of carnage.
  7. #67
    Jan 2009
    Holbrook, NSW
    73
    490
    Quote Originally Posted by scottyd View Post
    Hi Scott,
    Thanks for that, I had yours down as 16975 and 16976. I'll ammend the numbers.
    Mal
  8. #68
    Jan 2009
    Holbrook, NSW
    73
    490
    Quote Originally Posted by allterrain50 View Post
    Total number of Hercus lathes registered through AMH as at today 2261 of the 20799(highest number recorded) sold.
    Keep the numbers coming guys. As at today we have 2276 machines located.
  9. #69
    Sep 2014
    Elimbah Qld
    24
    Hi I don't have a Hercus lathe but I do have a 270 shaper Serial no 4Q2833 & a 3a tool & cutter grinder cant find the serial I'm sure it has been painted over if you know wher it is located ill try and find it .I got both machines from Gympie Qld they are now at Caboolture QLD
  10. #70
    Jan 2009
    Holbrook, NSW
    73
    490
    Quote Originally Posted by stevejw66 View Post
    Hi Steve,
    I haven't started a list for those machines as yet, but when I do I'll put yours in. Don't remember the location of the serial number on the 3A and can't check on my one as the machine is up in Sydney until some time in 2019. I'm sure one of the members will volunteer the info.
    Mal
  11. #71
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,542
    We have AR11101 in the Flinders Uni workshop.
  12. #72
    Jan 2009
    Holbrook, NSW
    73
    490
    Thanks Michael, with the others who have rung in. The total is now 2280.
  13. #73
    Richmond, NSW,Australia
    1
    Purchased one today Mal,
    A5212 coming from Springwood, NSW to Richmond NSW when the weather is cooler. Apparently purchased new in '55 by a machinist for home use (also in Springwood), bought by one bloke, then his mate and although filthy, appears to be in fairly good nick overall otherwise.
    Rob
  14. #74
    Jul 2011
    Adelaide
    837
    The serial number for the #3a and #1 tool and cutter grinders are on the right hand side of the sine table.
  15. #75
    Jul 2011
    Adelaide
    837
    Using the solution to the German tank problem from WWII https://en.wikipedia.org/wiki/German_tank_problem a better estimate for the number of Hercus lathes produced might be (20799 + 20799/2261) - 1 = 20807 unless we have more information?
  1. hercus serial no
    By tryhard202 in forum THE HERCUS AREA
    Last Post: 5th Nov 2012, 09:03 PM
  2. Hercus Model O Mill Serial Number.
    By triton2 in forum THE HERCUS AREA
    Last Post: 22nd Mar 2010, 03:48 PM
  3. Hercus Serial Number
    By Mark2 in forum THE HERCUS AREA
    Last Post: 22nd Apr 2009, 08:32 PM
  4. Hercus Serial Numbers
    By Drummond in forum THE HERCUS AREA
    Last Post: 28th Sep 2008, 10:55 PM
  5. Hercus 9" Serial Number BS316
    By bitza500 in forum THE HERCUS AREA
    Last Post: 25th Jul 2008, 01:38 AM
