Results 31 to 45 of 184
Thread: hercus lathe serial numbers
19th Jun 2016, 10:04 AM #31New Member
- Jan 2012
- 8
Hi Mal,i just picked up an old 9" model C
C6758
Matching bed and tailstock numbers. Got it for a steal! ($300) Bunch of tooling, 3 and 4 jaw chucks, jacobs chuck and live center.
I will be on the hunt for some change gears and steadies though (scottyd do you still have spares???). It has been converted to single phase, which is a shame (if anyone wants to swap setups with 3 phase, let me know!)
And has been "restored" at some point in the past...
19th Jun 2016, 01:07 PM #32australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
8th Jul 2016, 09:37 PM #33Novice
- Oct 2012
- Bittern, Australia
- 13
Hi Mal,
I have a Model C no 1908 (somewhere in the 40's I think. I have the original shipping invoice, sent by ship from Adelaide to Melbourne to McPhersons. I am the third owner.
I have made many modifications to the lathe including a countershaft clutch, a slotted cross slide from my own pattern, a taper turning attachment, rear toolpost, a copy of a South Bend lever operated tailstock with 6 station turret and single phase motor.I have 3 4-jaw chucks 2 3-jaw chucks and a recent aquisition a 4-jaw self centring chuck.. It is standing on cast legs (which are probably from a different lathe. I have spent a lot of time to align the lathe and it can turn within a thou over 15 inches. There is negligible wear in the bed but the tailstock base has been machined and shimmed. New half nuts were fitted. I have both sets of change gears, metric and Imperial (8 tpi leadscrew). A brilliant lathe. Regards, Borriss
8th Jul 2016, 09:50 PM #34Senior Member
- Jul 2012
- Griffith NSW
- 435
9th Jul 2016, 02:29 AM #35australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Welcome Borriss,
Your 1947 built Hercus makes only 24 from the 460 built that year, currently registered on the AMH database. Great to see you have been so active with your machine. If the legs are like the picture attached, they are probably genuine. Judging by the amount of owners who have sent me photos of their machines, they seem to have continued offering cast iron legs as an option into the late 50's and possibly early 60's.
Mal
9th Jul 2016, 07:51 PM #36Novice
- Oct 2012
- 13
Hi Mal,
The legs are similar to those pictured but do not have a straight crossbar but rather a circular ring spaced in the middle. I drilled and tapped the feet and put jacking bolts in to use to straighten the bed and level the machine. I also put some RHS tubing between the legs and the lathe drip tray to bring the machine up to a level I am comfortable working at.
Just for those that do not know the RGE in the circle on the tail end of the bed was the initials of R.G. Excel who was quality control inspector. He also signed all the test sheets supplied with the machines.
Borriss
9th Jul 2016, 08:22 PM #37Most Valued Member
- 5,945
I see the name R.G. Excel from time to time here, would his first name have been Rex? The reason that I ask, is that at the Day Centre where I help out, we had a Rex Excel there, as it's an unusual name just wondering if it's the same. Unfortunately I can't ask him, as he passed away about 5 months ago.
11th Jul 2016, 01:04 PM #38australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
11th Jul 2016, 10:31 PM #39Most Valued Member
- 5,945
Thanks for that Mal, I found that out on Sunday when I was doing a BBQ at the local Bunning, and was talking to a bloke that did his apprenticeship at Hercus.
When I get my lathe home, he'll come around and check it out for me.
Do you have any of the rotary switches or the handles? Are the three and single phase units the same?
19th Jan 2017, 09:22 AM #40New Member
- Mar 2010
- blue mountains
- 58
- 2
Hi I just picked a model A 5826, last time I used a lathe was about 1983 so I am rustler than it
19th Jan 2017, 02:21 PM #41australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
Welcome to the forum. Your lathe was built in 1956
27th Apr 2017, 06:54 PM #42New Member
- Mar 2011
- New Zealand
- 7
Help with serial number.
Apologies if this is wrong thread, feel free to move if it is.
I've got a model A lathe, but can't find a serial number anywhere ? The only plate on it is one with metric thread conversions on (which as model A stamped on). It's an ex New Zealand Dept of Education machine.
Would there be anything stamped anywhere?
27th Apr 2017, 09:42 PM #43Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
On my 9A, the serial number is stamped at the right hand end of the bed, on the horizontal surface between the two rear vee ways.
Jordan
27th Apr 2017, 11:30 PM #44australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
See the attached picture
28th Apr 2017, 12:17 PM #45New Member
- Mar 2011
- New Zealand
- 7
AAH, found it !
Number is A6301, there is an inspectors stamp RGB as well. Based on another you have dated I'm guessing this would be mid '60s ?
hercus serial no
By tryhard202 in forum THE HERCUS AREAReplies: 1Last Post: 5th Nov 2012, 09:03 PM -
Hercus Model O Mill Serial Number.
By triton2 in forum THE HERCUS AREAReplies: 2Last Post: 22nd Mar 2010, 03:48 PM -
Hercus Serial Number
By Mark2 in forum THE HERCUS AREAReplies: 7Last Post: 22nd Apr 2009, 08:32 PM -
Hercus Serial Numbers
By Drummond in forum THE HERCUS AREAReplies: 18Last Post: 28th Sep 2008, 10:55 PM -
Hercus 9" Serial Number BS316
By bitza500 in forum THE HERCUS AREAReplies: 12Last Post: 25th Jul 2008, 01:38 AM
