Page 2 of 13 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 184
  1. #16
    Jul 2012
    Griffith NSW
    435
    Ive got CTM 16086
    Its another ex-school machine, from west wyalong HS. I think this machine has either been parked next to a grinder or been used to cut a lot of cast iron, the bed is past its prime. Its not so bad that its not capable of most work, even being reasonably accurate over a longish cut. The tailstock base is worn also, a little lower than level and enough to annoy me. I think its a bitsa, which isnt unusual for a school machine. The leadscrew is in excellent shape, yet it had half nuts that were worn to the point where they would no longer hold the screw at all, which makes me think the original ones were swapped out and I got the duds. The lathe is acceptable, for $400 is a good deal. But what I got with it made it a great deal. I got all of West Wyalong's change gears, a heap of steadies and a whole bunch of tooling. If anyone needs some 9in steadies, I got a few to spare here, fixed and travelling! My machine will eventually be converted to ATM spec, I used to have QC boxes with my last schools 260's and they were indeed nice to have. The powered cross feed is also missed.
    Ive also got 6 machines, all hercus 9in's at school under my care, one day ill get the serials and post em up. They are mostly in good shape, but the spindles have suffered from neglect in the form of a lack of oiling for years. They are still capable of doing some good work. I believe the serials are in the early 9000's and all six are consecutive if i recall correctly.
  2. #17
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by scottyd View Post
    I might be interested in a travelling steady Scotty. I have a 260ATM. Will one of your 9's fit my machine?
  3. #18
    Nov 2005
    adelaide
    597
    9 inch and 260 travelling steadys are different see here http://www.australianmetalworkinghobbyist.com/store/
    john
  4. #19
    Jul 2012
    Griffith NSW
    435
    Tanii51 is right. What the real problem is and why Id rather be rid of them is that there isnt enough metal off the bottom of the steady to get down to anything that could be used to hold the steady on the 260. Perhaps with some serious surgery on the steady and maybe even on the lathe, you could achieve something...but it smells an awful lot like hard work.
  5. #20
    Nov 2007
    melbourne australia
    3,228
    Thanks gents
  6. #21
    Jan 2009
    Holbrook, NSW
    73
    490
    Default 9" steady on a 260
    The 9" hercus steady can be used with a riser block (readily available) on the 260, they both have the same work holding capacity.
    Mal
  7. #22
    Aug 2014
    Perth, Western Australia
    72
    28
    Default My New (Old) Lathe
    I have just aquired a Hercus 9" AR 13503 which I think makes it a 1971. Matching numbers. Worn out Half nuts (replaced) and lots of swarf (removed). Need a lick of paint but otherwise seems fine.
  8. #23
    Feb 2015
    Croydon
    1
    Default New (old) Hercus lathe
    I have purchased a Hercus Model C lathe.
    RGE VB783
    Daubed in cream coloured paint. My intention is to strip it down, clean it up and repaint it.
    The lathe works.
    Keith
  9. #24
    Tiptoeturtle Guest
    Quote Originally Posted by Keith_L View Post
    RGE VB783
    The lathe works.
    Keith
    They just "keep on keeping on", apart from the paint that is. I do not remember if it was Rolf Harris or someone else who said that. I am pretty sure he used to say (in TV commercials in the 1960s or 1970s) "Trust British Paints ? Sure Can."
    Any older and they might start carbon dating the paint in your lathe.
  10. #25
    Sep 2008
    Queensland
    445
    Hercus 260 model ATLM 17788
    I have been meaning to post this for a while now just been lazy its been sitting in bits for to long so ill post on the rebuild to. I pick this lathe up from a engine rebuild shop that buys out shops then sells the surplus. It came from an engine shop in Sydney the guy said it was in a basement as the shop had 2 stories and a split level between. The curiosity about this lathe is the cabinet is to old and short for the 260 I believe they had an older 9" workshop lathe they retired then bought the 260 without a cabinet. maybe the boss was trying to save money and thought the bolt holes were the same but they were not. The cabinet has suffered some abusive cut and shut work but it is ok for now. I found like a 3" crank bush wedged in the cabinet this lathe must have had a long life and now its all mine
    happy turning
    Patrick
  11. #26
    Jan 2009
    Holbrook, NSW
    73
    490
    Quote Originally Posted by new_guy90 View Post
    Hi Patrick,
    Thanks for the serial number. No wonder it wouldn't fit on the old cabinet as the ATLM is 9" longer.
    regards Mal
  12. #27
    Feb 2007
    humpty doo N.T
    48
    54
    I just got mine and it is 260 ATLM 18990
    From a school that said it has never been used just stored.
    Cheers Rum Pig
    It is easier to ask for forgiveness than permission.
  13. #28
    Jan 2009
    Holbrook, NSW
    73
    490
    Hi Rum Pig,
    Thanks for the number, sounds like you got very lucky.
    Mal
  14. #29
    Jan 2009
    Holbrook, NSW
    73
    490
    quite a few owners have wrecked machines to get parts, I would like to put the numbers these machines on my list as well, if you have a numbered tailstock, bed or gear plate, please let me know the number.
  15. #30
    Aug 2015
    Brisbane
    1
    Hi,
    about 12 months ago I bought my first lathe a Hercus 14 X 40 serial # 7R-187
  1. hercus serial no
    By tryhard202 in forum THE HERCUS AREA
    Last Post: 5th Nov 2012, 09:03 PM
  2. Hercus Model O Mill Serial Number.
    By triton2 in forum THE HERCUS AREA
    Last Post: 22nd Mar 2010, 03:48 PM
  3. Hercus Serial Number
    By Mark2 in forum THE HERCUS AREA
    Last Post: 22nd Apr 2009, 08:32 PM
  4. Hercus Serial Numbers
    By Drummond in forum THE HERCUS AREA
    Last Post: 28th Sep 2008, 10:55 PM
  5. Hercus 9" Serial Number BS316
    By bitza500 in forum THE HERCUS AREA
    Last Post: 25th Jul 2008, 01:38 AM
