Results 1 to 15 of 15
19th Jan 2011, 10:49 AM #1Senior Member
- Aug 2010
- Springwood
- 168
Hercus 9inch travelling steady castings
Hercus Owners
I have a pattern for the 9" travelling steady and will get some cast soon. Send me a PM if you want to be added to the list.
There'll be two cast iron fingers and the main steady body.
The body doesn't need much machining, four tapped holes ,two slots for the fingers and two slots for the fixing bolts. Price around $40 plus postage.
Hercus 260 travelling steady casting also available.
Peter.
26th Jan 2011, 06:22 PM #2Turning useful pieces of steel into scrap metal.
- Jun 2010
- Riverina, NSW, Australia
- 68
- 138
Swarfmaker1, you may have seen my previous thread regarding myself looking for a travelling steady for my Qualos lathe. No luck so far on that front.
I might be interested in adapting a steady from the 9" Hercus for my Qualos.
Can you supply the dimensions of the Hercus travelling steady?
* The length of the base
* The width of the base
* The centre height of the steady (Height above the base).
Also is the base machined or can I get a green/unmmachined casting?
26th Jan 2011, 07:39 PM #3Senior Member
- Aug 2010
- Springwood
- 168
The Hercus travelling steady is an odd shape casting. Almost line an 'S' shape that bolts onto the side of the carriage. If you can supply a picture of the Qualos and basic dimensions I possibly get one made for you or if you can make your own pattern and send to me I can take it to the foundry for you and have it cast. That's probably the best option.
Peter.
31st Jan 2011, 06:59 AM #4Turning useful pieces of steel into scrap metal.
- Jun 2010
- 68
- 138
So this steadys are not like the 260 Hercus which I believe have the long flat style of base?
31st Jan 2011, 07:29 AM #5Turning useful pieces of steel into scrap metal.
- Jun 2010
- 68
- 138
Sorry I forgot earlier to add a couple of images that I've found on ebay at another time. So this isn't my Qualos machine. The travelling steady is obvious in both images and gives a good view on the type of steady that I'm looking for.
31st Jan 2011, 07:38 PM #6Senior Member
- Aug 2010
- Springwood
- 168
1st Feb 2011, 12:25 AM #7Turning useful pieces of steel into scrap metal.
- Jun 2010
- 68
- 138
Swarfmaker1,
From measuring the travelling steadys mounting points on my Qualos it appears the base is about 9.5" - 10'' long, about 1.25" wide. and 7.75" between the fixing bolts centres. Height from the bottom of the base to centre height is 4".
1st Feb 2011, 04:02 PM #8Senior Member
- Aug 2010
- Springwood
- 168
3rd Feb 2011, 03:10 PM #9Novice
- Jun 2010
- Point Clare, Central Coast NSW
- 12
G’day all. Thanks all for the feed back on the correct positioning of gears to have me cut threads. Did the job very well.
Swarfmaker just triggered a thought about the steady that came with my recently acquired A Model. The steady appears to be positioned on the top of the saddle. There is an impression left there of a fitting which may allow the fixing of the traveling steady. I don’t have that fitting but I don’t believe that the two very small screw holes on the top of the saddle will do the job - so if there’s anyone there that may enlighten me how the steady fixes in place ??
Pictures below.
As an aside - Just finished resurrecting my old compressor, vintage 1954 called a “Ben Patent”. Had to get a new Motor, the old one was three phase, used the old pulley which had a 1 inch shaft, new one has a 3/4 shaft, so had to turn a bush and then key it. The Hercus did the job. The compressor runs a lot faster, the old motor ran at half the speed so it tends to vibrate a bit across the floor !! A little anxious wondering if the diaphragm that I replaced would do the cut of and cut in job but it works great. Set the cut of for 100psi and cut in at 75 psi, enough for the odd job I need but may have to downsize the motor pulley a bit later. Nice to have a bit of air for the workshop.
3rd Feb 2011, 05:04 PM #10Senior Member
- Aug 2010
- Springwood
- 168
Downunderoz, Those screw holes look non standard. Probably put there by one if the previous owners.
Peter.
3rd Feb 2011, 07:32 PM #11Most Valued Member
- 4,887
The travelling steady fixes to the Tailstock side of the carriage,there should allready be 2 taped holes for it.
5th Feb 2011, 02:10 PM #12Novice
- Jun 2010
- 12
Thanks Pipeclay ans Swarfmaker1.
I'll check out the other side of the carriage. Should have figured out that one with the offset on the steady.
29th Mar 2019, 10:05 AM #13
Hi Peter,
I recently purchased a 9" A model lathe & in search of a fixed & travelling steady. They don't appear to be commonly available on the usual selling sites such as EB & GT. Did your proposal ever proceed & if so do you still have any on offer.
Regards Wayne
30th Mar 2019, 08:08 AM #14Member
- Nov 2018
- Tasmania
- 97
Do you have any photos of the travelling steadies?
I'd be interested in getting one
30th Mar 2019, 10:05 AM #15Most Valued Member
- 5,942
Swarfmaker hasn't been on here for nearly 2 years.
You'll find a picture of the travelling and fixed steady on here with prices.
https://australianmetalworkinghobbyi...er_name=steady
Call Mal 0438466008 or email search requests to [email protected].
HTH
Travelling steady for a B model Qualos
By Metmachmad in forum METALWORK GENERALReplies: 34Last Post: 2nd Sep 2011, 11:49 PM -
travelling steady
By azzrock in forum THE HERCUS AREAReplies: 7Last Post: 30th Dec 2010, 11:23 AM -
N.S.W. Hercus Vertical Milling Attachment Castings etc
By Swarfmaker1 in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 7th Dec 2010, 10:13 AM -
wanted... 9inch Guard
By yogie in forum METALWORK GENERALReplies: 6Last Post: 15th Dec 2007, 11:45 PM
