Results 1 to 8 of 8
Thread: travelling steady
27th Dec 2010, 02:54 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
travelling steady
hi all. just wondering if the travelling steady on a hercus 9" bolts to the rear of the
cross slide?
and has any one here made a fixed or travelling steady for a 9". they just seem a little expensive. im shore they are good quality and all. but nearly half the price of my hole machine.
27th Dec 2010, 05:38 PM #2.
- 6,458
Azzrock,
They bolt onto the tailstock side of the saddle. The cross slide is in the way in the photo. It's made to fit the saddle equipped with the standard slide. I would have to install spacers for clearance to enable the steady to fit under the extended slide.
Regards Bob.
28th Dec 2010, 12:23 AM #3Most Valued Member
- Oct 2010
- 1,910
hi bob thanks for the reply. do u use yours very often. great photo. whats the deal with your saddle.
that looks handy. did you make it?
28th Dec 2010, 12:37 PM #4Senior Member
- Sep 2008
- Queensland
- 445
the T-sloted cross slides are quite rare but was offered as an extra by Hercus you can use it for all sorts of stuff like odd boring and milling jobs actually i think the T-sloted slide on the Myfords contributes a great deal to there popularity since they came standard
if you are interested here is where you can get a casting
this thread details its machininghappy turning
Patrick
28th Dec 2010, 01:31 PM #5.
- 6,458
No, I didn't make it. I bought it new from Hercus along with a boring table. They are both 260 items. The extended slide is higher than the standard cross slide by about 4mm. Using the Hercus 4 way toolpost requires the instalation of a thinner spacer under the post. Just having the ability to mount a rear tool post makes the acquisition of an extended slide worthwhile.
I have 2 small milling machines and sometimes it is not possible to machine a surface because there is insufficient space between the cutter and the table to mount the workpiece. The lathe has proven handy in these situations. The last photo below shows a set up using the boring table to support a component of a slotting head I was making, that required spot facing. Some fiddly shimming was required to centre the cutter on the same centreline of an existing hole.
So far I have never used the travelling steady. I should just so I know what it's like to use.
I have used the fixed steady on numerous occasions and wouldn't be without it.
If I had to buy (or make) one before the other, I'd choose the slide first.
Bob.
p.s. The masonite hides the mess in the background.
28th Dec 2010, 06:27 PM #6Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I like Bob's Hercus slotted cross slide over my South Bend / Boxford type that has the mounting hole for the compound slide farther back, with a slot on the nearside of it. I can't get the cutting tool far enough forward for some jobs.
I see the milling table has a feature that would help, in the form of a machined arc that lets it move over the cross slide dial instead of bumping into it.
Jordan
29th Dec 2010, 10:46 PM #7Senior Member
- Sep 2008
- Queensland
- 445
nice set up photos Bob is that a scissor knurl on your rear tool post?
happy turning
Patrick
30th Dec 2010, 11:23 AM #8.
- 6,458
Sure is Patrick. My homemade version.
