Results 1 to 12 of 12
Thread: 5/8 tapered pin reamer
15th Nov 2010, 02:27 AM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
13/32 tapered pin reamer
hi does any one have a 13/32 or 10.3 mm tapered pin reamer that they would like to sell?
is there a roughing and finishing reamer for tapered holes?
i mead it for making a tapered holeLast edited by azzrock; 15th Nov 2010 at 09:42 PM. Reason: i got the size wrong
15th Nov 2010, 03:29 AM #2Most Valued Member
- 4,887
Not sure about the 2 reamers but you will need to use a tapered drill.
15th Nov 2010, 03:34 AM #3Most Valued Member
- Oct 2010
- 1,910
i remember when i was an apprentice we used a roughing reamer to cut the Morse taper in the tail stock of the lathe we made. i haven't seen one since thou
15th Nov 2010, 03:52 PM #4Most Valued Member
- 4,887
Are you after a reamer for the 5/8" or 10.3mm or both.
15th Nov 2010, 08:34 PM #5
I think he wants a reamer to ream a hole for a tapered pin , not a tail stock .
I've never seen a tapered drill for drilling holes for taper pin reamers ,
just drill a hole the smallest diameter of the reamer and have at it , they are mostly hand reamers any way.
No roughing or finishing reamer just the one .
Biggest taper pin reamer I have is a no 6 , nowhere near 5/8"
Kev"Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
15th Nov 2010, 08:54 PM #6Most Valued Member
- 4,887
I believe from what was asked that he was after a tapered reamer for either of the sizes he stated or both as the sizes given are not covered by the 1 reamer.
In regards to taper pin holes I have in most cases allways roughed with a tapered drill first then reamed to finished size.
In a pinch you could drill a series of stepped holes through your workpiece and finish with the reamer but care would need to be taken,depending on the quality of the finished fit and application.
15th Nov 2010, 09:36 PM #7Most Valued Member
- Oct 2010
- 1,910
yah good question i only need the 10.3 or 13/32 reamer i all ready have the. 5/8. it must be all these nights at work. playing with my head.
15th Nov 2010, 09:46 PM #8Most Valued Member
- Oct 2010
- 1,910
i do need it for making a tapered hole.so one with a no. 2 morse taper would be great. i was just asking because i thought someone might have one laying around. like i have tool that don't get much use.
18th Nov 2010, 12:16 PM #9Most Valued Member
Can't help with the reamer sorry(althought I have thought about buying a couple now and then).
Yes there are roughing reamers.
An MT2 reamer isn't going to go into a 10.3mm hole
MT2-2PCE Morse Taper Reamer Set (COARSE & FINISHED) (eBay item 270664699221 end time 16-Dec-10 09:47:03 AEDST) : Industrial
Do you mean MT1?
MT1-2PCE MORSE TAPER REAMER SET (COARSE & FINISHED) (eBay item 350407197744 end time 24-Nov-10 09:19:43 AEDST) : Industrial
18th Nov 2010, 01:12 PM #10
18th Nov 2010, 07:24 PM #11Most Valued Member
- Oct 2010
- 1,910
the no. 2 morse taper part was for holding it in my tail stock. thanks for the help.
18th Nov 2010, 08:03 PM #12Most Valued Member
Doh I thought I might have been missing something
HSS Adjustable Reamer set
By blackwoods in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 12th Oct 2010, 05:38 PM -
How do you Use a hand reamer
By rodm in forum METALWORK GENERALReplies: 11Last Post: 7th Feb 2010, 08:28 PM -
1MT Reamer
By Garell in forum METALWORK GENERALReplies: 3Last Post: 11th May 2006, 11:24 PM
