Results 1 to 15 of 58
Thread: cross feed screw
30th Oct 2010, 05:55 AM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
cross feed screw
hi im new here. can any body please help me find a cross feed nut and screw. for a 9" c model .
allso a tread chasing dial would be a great help.
thanks.
aaron
[email protected]
31st Oct 2010, 02:38 PM #2Most Valued Member
- 4,890
Could do a NEW bronze nut for $65
31st Oct 2010, 04:26 PM #3Most Valued Member
- Oct 2010
- 1,910
that sounds ok. what part of australia are you from and do you have any other handy items to sell?
i have been thinking a more ridged tool post might be a good start.
thanks
31st Oct 2010, 04:32 PM #4Most Valued Member
- 4,890
Im in Sydney,depending on what your after most parts are available.
31st Oct 2010, 04:36 PM #5Most Valued Member
- Oct 2010
- 1,910
ok cool do u have a web site. id like a thread chasing dial.
thanks for your help
31st Oct 2010, 05:43 PM #6Most Valued Member
- 4,890
No sorry no Web site most parts are good 2nd second hand,and some parts new .
Not all New parts are original Hercus but are compatible with the 9" or 260.
31st Oct 2010, 06:59 PM #7Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
azzrock,
You mentioned you would like a more rigid tool post. If you have access to a mill, you could possibly make one. I have some drawings for a Hercus 4 way tool post, or contact member allterrain50, he may be able to help you out.
Ken
31st Oct 2010, 07:52 PM #8Most Valued Member
- Oct 2010
- 1,910
good idea i think i will. its ill have to do when no one is looking. and find some tooling
31st Oct 2010, 09:10 PM #9Product designer retired
- Nov 2006
- 79
- 2,074
azzrock,
Attached are some drawings of a 4-way tool post you may find of interest.
Only too happy to welcome and help a new member.
Ken
31st Oct 2010, 09:31 PM #10Most Valued Member
- Oct 2010
- 1,910
31st Oct 2010, 09:59 PM #11Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
31st Oct 2010, 10:37 PM #12Product designer retired
- Nov 2006
- 79
- 2,074
nadroj,
Well spotted, if you have details of the thick washer, I'll include it with the other drawings.
I presume it sits between the main block, and the top of the compound slide. I don't actually have my lathe up and running yet, so didn't realise it was missing.
Ken
1st Nov 2010, 03:22 PM #13Member
- Aug 2009
- Lake Macquarie
- 86
- 90
Ken,
I have another style of Hercus Craftsman 4-Way Toolpost.
With the exception of the the underside counterbore, the Toolpost dimensions are as your drawings.
Mine has indexing cut outs on the underside of the toolpost which engage with the chisel shaped 'dog' located in the T-Nut.
The counterbore houses the spring which pushes up the toolpost and dis-engages the dog when the handle is released, allowing the tool to re positioned at another angle.
The two grub screws at each end of the T-Nut just clamp the T-Nut.
Is this a Hercus standard?
I have since found that the lathe came from a Met-Lab in Sydney and was used to make Denison test pieces, so it could have been made there.
I received some 16mm indexable insert tools with the lathe which brings the cutting edge exactly on centre height.
Col
1st Nov 2010, 03:37 PM #14Product designer retired
- Nov 2006
- 79
- 2,074
Hi Col,
I can't comment if your tool post is standard, I don't have any knowledge of the Hercus Craftsman lathe.
The indexable feature sounds like a good idea.
Do you have a thick washer with yours as mentioned above by nadroj?
Ken
1st Nov 2010, 04:31 PM #15Member
- Aug 2009
- Lake Macquarie
- 86
- 90
Hello Ken,
Thanks for the reply
My toolpost does not need the large washer as it clamps directly to the compound.
Col
