Results 1 to 10 of 10
Thread: Flat Belt Retailers
21st Jul 2010, 10:02 AM #1Rodddd
- 48
Flat Belt Retailers
Hi Listers,
I have a question for the greater minds out there - where does one purchase flat belts these days (or the materials to make up one)?
I have a need of a flat belt (which I am guessing would have been originally leather) about 50mm wide and (eventually) in a ~2m loop.
Some of you may have seen that I am now the proud owner of a 21" Hercus Drilling Machine that needs a belt between the two speed reducing cones at the back of the machine. I will have to join the belts as the supports for both shafts are continuous so I won't be able to get a continuous belt over the cones and through the shaft supports..
What would be the recommended material for the belts?
Thanks in Anticipitation
Rodd.
21st Jul 2010, 10:12 AM #2Most Valued Member
Hi Rodd
I got mine for $60 about 10 years ago from powergrip when they were still in Boxhill.
Powergrip - Flat Transmission Belting
I went to Rowville a few years back and they had a cash sales counter then so I guess they still do.
I had the old one as a sample.
21st Jul 2010, 02:19 PM #3Rodddd
- 48
Hi Stuart,
Thanks for the info. I downloaded a catalogue and will chase them up in a couple of weeks when I'm closer to installing the belt (next challenge!).
Rodd.
22nd Jul 2010, 06:02 PM #4Golden Member
- Mar 2010
- Nth Qld
- 687
Don't forget there are far more modern materials that flat belts are available in than leather. I've been eyeing off this kevlar cored material that should be ideal.
22nd Jul 2010, 10:04 PM #5danielson
- Dec 2009
- broadford
- 63
- 213
f d o,conners in thomastown are the belting specialists and supply the bearing shops etc.they sell direct to the public and are happy to provide great service.i have no connection to this company.he will make up any length belt you need in leather or manmade.
23rd Jul 2010, 06:59 PM #6Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I'm using a poly-V belt on my belt drive Hercus. It's working well since I found out that, contrary to advices, the belt should not be fitted flat side to pulleys - it slipped that way.
Jordan
24th Jul 2010, 10:06 AM #7australian metalworking hobbyist
- Jan 2009
- Holbrook, NSW
- 73
- 490
leather belts
Hi Rodd,
Your local craft, come leather merchant should be able to supply bridle leather in whatever width you want plus to tools and glue to join it. I made one for my 45 model C which works well.
Mal
28th Jul 2010, 11:21 AM #8Rodddd
- 48
Thanks for the feedback. I have found a couple of sythentic belts that may be suitable, so will have somewhere to start in a few(!) weeks when I am up to that stage of the reno.
Thanks again.
Rodd.
8th Aug 2010, 11:49 AM #9Novice
- Jun 2008
- adelaide
- 23
Leather belts.
Hi Rod. In replacing the leather belt on my elderly Hercus I found the harness maker at a local race course, told him what I wanted and what fore. He selected the "right leather"
slit it to the width/length I specified and supplied 2 lengths for $20.oo I joined the belt using a gel type commercial contact cement after tapering the faces of the belt for a length of 5" as described in the South Bend Lathe book.
Bill C.
18th Aug 2010, 11:40 AM #10Member
- May 2007
- Ferndale
- 79
Rydell Industrial belting (in WA) supplied mine, cc over the phone and one of the guys even dropped it off after work, same day I broke the leather one (more joiners than leather in the end). Hows that for service. They have got my business.
No affiliation except as happy customer.
Frank
