Results 1 to 15 of 17
Thread: Motor replacement
16th Nov 2009, 10:19 PM #1Member: Blue and white apron brigade
Motor replacement
I'm interested 3Ph to 1Ph motor replacement experiences.
What 1Ph HP motor is recommended.
Any tricks and tips to watch out for?
Maybe there's a thread on this already - I searched but couldn't find anything.
16th Nov 2009, 10:34 PM #2Most Valued Member
- 4,890
Depending on what you want to do and how much you want to spend either a 1/2 HP 3/4HP or 1HP.
Would also suggest that you get a motor that is reverseable,and a Drum switch.
16th Nov 2009, 10:47 PM #3Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Bobl,
I reckon you'll need a 3/4HP motor, 1425 rpm or thereabouts with a pulley about 2.25" to 2.5" in dia.
This subject has been covered before, but can't find it either. I recently purchased Crompton motor on eBay for around $180, shaft size 5/8" dia with correct mounting plate.
If you type "Crompton electric motor" into eBay, you will come up with many alternatives. They are made in India, and seem to be of good quality. The motor is reversible, as Pipeclay suggests.
I have no connection with the Seller.
Ken
16th Nov 2009, 10:49 PM #4Member: Blue and white apron brigade
Thanks Pipeclay,
Couple more questions
What RPM should the motor be?
And would something like this be OK?
https://www.machineryhouse.com.au/Pr...stockCode=E050
I realize it will need a drum switch and be wired for reversing.
16th Nov 2009, 10:55 PM #5Member: Blue and white apron brigade
16th Nov 2009, 11:22 PM #6Most Valued Member
- 4,890
That motor should be fine,if thats what you decide on I would suggest you contact CMG direct as I think there prices may be lower than stated in the add,not sure if there in WA but they are in NSW,
17th Nov 2009, 08:01 AM #7Golden Member
- Nov 2005
- adelaide
- 597
ive just gone throught the same process one thing i found make sure the capacitor housing is on the top of the motor or you will have to extend the mounting plate out further. also i have fitted an adjustable pulley made by braemer ( comes off an aircondioner) whereby one side of the pulley can be screwed in or out to make different diameters 2 belts of different lengths are needed though ...i havent used the bigger diameter yet
17th Nov 2009, 10:28 AM #8Member: Blue and white apron brigade
17th Nov 2009, 09:35 PM #9Golden Member
- Nov 2005
- adelaide
- 597
1hp 1440rpm CMG and reversable.... Bob only because i had one ...before that i had a 1/3 hp washing machine motor which worked fine for most things but using higher speeds for tungsten carbide tools stressed it out till it finally died but it was probably 50+years old. I still use slack belts incase i stuff up some where
17th Nov 2009, 10:16 PM #10Most Valued Member
- 4,890
Just curious as to the max depth of cut you might be taking and the feed rate you are also using and the type of material you have cut with your 1 HP with slack belts.
17th Nov 2009, 10:50 PM #11Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Hercus Motor Sizes
HI, I spoke to Hercus a Year or two ago about Motor H.P. sizes. I have a Model A Hercus Plain Bearing Lathe. They told me 1/2 H.P. Is Standard, but they will handle a 3/4 H.P. Motor. I would think that on a Roller Bearing Hercus (Model A Type) a 3/4 H.P. or 1 H.P. Motor would be suitable. There is a Mob on Ebay selling Forward / Reversing Switches for about $99.00 plus Post. I think it is the same ones that sell the Crompton or CMG Motors on Ebay.
All The Best steran50 StewartLast edited by steran50; 17th Nov 2009 at 10:51 PM. Reason: forgot is
17th Nov 2009, 11:11 PM #12Member: Blue and white apron brigade
Thanks Guys - all very useful stuff.
18th Nov 2009, 10:38 AM #13Golden Member
- Nov 2005
- adelaide
- 597
pipeclay the belt has about 1 inch deflection in the middle(thespeed change)and its one of those link belts as for feed rates and depth i m going gentle only max of 2mm depth approx on roughing cuts and hand feed rate just so it feeds easily without too much chatter or vibration ......as slow as it will go with auto feed 450 rpm till im confident i can up the feed and speed rates all with tungsten carbide tooling
screw cutting as slow as i can get it
18th Nov 2009, 10:57 AM #14Most Valued Member
- 4,890
The depth of cut seems ok,I find with mine at .100 doc and .002 feed at 500/700 rpm it seems to labor a bit,but dosent mind .080doc.
I thought maybe with you saying that the belts were a bit slack that your doc might of been restricted.
18th Nov 2009, 11:54 AM #15Golden Member
- Nov 2005
- adelaide
- 597
i did it deliberatley as i think maybe 1 hp is a bit much so if i leave the belt a little slack maybe it will prevent something drastic breaking if i do something wrong as it is if i apply to heavy a feet rate or cut the belt starts to slipso i know to back off
