Results 1 to 10 of 10
Thread: source of 8in trailer wheels
24th May 2008, 10:44 PM #1Hammer Head
- Jan 2005
- 55
i need to make some large dollys for work to move around packs of plywood weigh a ton each.
i want to use a wheel with a tyre so it can go over bumps as normal hard industrial wheels just stop.
looking today on ebay i saw small trailers with 8in wheels, does any one know a source of these in syd.
also require axles as well,
the wheels need to be able to turn so the axle might be rotating on a centre point, any ideas please pass them on.
thanks
25th May 2008, 10:13 AM #2Most Valued Member
- 4,890
How many do you need to make,have you thought of using the pneumatic type of jockey wheel set up for your end pivot steeringMaybe try bunnings and see what they have in regards to pneumatic wheels,if you have access to a drill and welder should be too hard to fabricate your on pivot assembly for steering .
I take it you would be having a single wheel front and rear for steering and 2 wheels in the middle of your frame on the outside.
25th May 2008, 10:25 AM #3
25th May 2008, 03:49 PM #4Hammer Head
- Jan 2005
- 55
25th May 2008, 05:13 PM #5
25th May 2008, 05:33 PM #6Most Valued Member
- 4,890
Not sure if the ones at bunnings are 300lb or 300kg rated,youll find those in the gardening section.
Give Moore Equipment a call 9519 5540 they have a wide selection.
What is the surface your moveing over,they have pneumatic 250mm OD fixed and swivel rated to 225kg.
They also have rubber tyred types at 200mm OD rated to 300kgs.
25th May 2008, 08:33 PM #7Old Chippy
- Mar 2007
- Canberra
- 72
- 70
Talk to your nearest CBC Bearings store.
Look at their website and go to castors where you will see that they sell all manner of industrial castors and wheels - including up to 10 tonne wheels!
I bought a set of castors to put under my ancient 8" Primo jointer that was a cast iron bed with a cast iron base - weighed around 400kgs and CBC had a range. As it happened I wanted non-marking ones and they had them - with or without brakes etc etc. Put one on each corner (with two on diagonals having brakes) and was able to move it around with ease.
I am sure they will have a solution for your need and they are reasonably priced given they are good quality.
http://www.conbear.com/
25th May 2008, 09:21 PM #8Golden Member
- Nov 2005
- adelaide
- 597
what about 9 inch alloy boat rims (sent you a pm)
26th May 2008, 03:18 PM #9
Aunger were doing a sheetmetal flatpack trailer a while ago with 8in pneumatics bolting onto hubs. Sold through Kmart and Repco, Repco still had them a while ago. An accessory for them was a spare tyre and rim, or a tyre, rim, hub, and stub axle as a drawbar bolt on spare everything set.
Tyre and rim was abt $50 from memory.
4.8 x 4 x 8 4 ply tyre load rating 270kg ea 4 studs on approx 100mm diameter circle Highway rated tyre.
Try Repco, Aunger, or ebay in that order
26th May 2008, 09:41 PM #10
What type are you chasing?
When I was at Melbourne Trailer & Caravan Supplies (03 9772 2333), they had several 8" rims available. Here's the list;
- 8" x 2.5" low speed needle roller bearings (requires matching axle or shaft)
- 8" x 2.5" split rim with HT stud pattern (bolts to a std HT trailer hub)
- 8" x 2.5" with integral tapered roller bearings (goes onto std trailer stub axle, high speed)
- 8" x 3.0" wider version of above
- 8" x 3.5" one piece HT stud pattern
- 8" x ??? I think they were 5 or 6" wide, Mini 4 stud, suits knobby ATV tyres (Not cheap!)
As for the jockey wheel, Manutec do a 10" diameter pneumatic 'look-alike' that's solid rubber. Won't go flat!! Unsure of carrying capacity. You could see if you could buy the fork part of the jockey wheel separately as pivot for the front. Cheaper than buying the whole jockey wheel.
Just found it...
Yonnee.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Trailer
By rod1949 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 26Last Post: 29th Sep 2009, 02:28 PM -
WIP - Trailer
By Wood Butcher in forum TRAILERS & OTHER FABRICATED STUFFReplies: 20Last Post: 14th Jan 2007, 11:44 PM
