Results 1 to 9 of 9
19th Dec 2018, 01:27 AM #1
Looking for one offcut of composite panel
Hi. Several people here have built enclosed trailers using rigid sandwich panel. I can't seem to find any sources for a smallish piece.
I'm looking for about 450 x 600 (or a little bigger, up to 600 x 750) in either 20 or 25mm thickness. I don't mind if the sides are aliminium of a hard plastic, nor if the core is foam or honeycomb material - it just has to light and rigid.....
Any idea where I might find something like that? What common industry do I look in or phone up?
Cheers.Cheers, Joe
19th Dec 2018, 01:43 PM #2
Best I could come up with is this
https://rover.ebay.com/rover/0/0/0?m...2F292853291918
Bit far though, think it is qld
Sent from my iPad using Tapatalk
19th Dec 2018, 04:26 PM #3Most Valued Member
- 2,672
Southeast plastics in Braeside do half sheets.
They've got an ad on gumtree - search for "composite panel"
19th Dec 2018, 06:15 PM #4
Refrigerator/Cool Room manufacturers would be my guess. Some Sheet Metal fabricators may have some as well
Just do it!
Kind regards Rod
19th Dec 2018, 06:33 PM #5Philomath in training
Sign writers?
19th Dec 2018, 08:43 PM #6
Thanks for those responses. As you can imagine, I had already found the eBay and Gumtree offers....
I will however check out the local sign writers. Good idea Michael.
Failing that, next time I'm in the Southern suburbs of Melbourne, I'll see if I can call in at Breaside (a 3 hr drive from here).Cheers, Joe
19th Dec 2018, 09:20 PM #7Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
It is also used by caravan manufacturers.
19th Dec 2018, 09:21 PM #8Most Valued Member
- 2,672
Would a 490x520x28 piece of fiberglass skin over aluminum honeycomb core do the job?
Currently sitting on my workbench at home if you want it.
19th Dec 2018, 10:37 PM #9Most Valued Member
- Jul 2016
- 35
- 1,522
Braeside is really really close to me if that helps, I could stash it for a weekend pickup?
Vfd control panel
By russ57 in forum ELECTRICALSReplies: 7Last Post: 29th Mar 2017, 01:19 AM -
Solar panel indexer
By Steamwhisperer in forum METALWORK PROJECTSReplies: 32Last Post: 8th May 2016, 08:23 PM -
remake panel
By jackaroo in forum METALWORK GENERALReplies: 10Last Post: 11th May 2008, 10:07 PM -
7 x14 control panel puzzle?
By Malfie in forum METALWORK GENERALReplies: 3Last Post: 11th Jul 2007, 11:35 AM
