Results 31 to 36 of 36
Thread: Will this plan work?
2nd Sep 2018, 05:25 PM #31Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Hi guys me again, Does anyone know how long it takes for 6061 or 6082 both T6 to self harden i i anneal it?
3rd Sep 2018, 05:27 PM #32Most Valued Member
- Sep 2010
- Lebrina
- 1,916
I take it that you want to anneal so as to make the bending easier. If you anneal the material, you will be left with a material of unknown mechanical properties and ageing will restore only some of the properties. Altogether not a good idea when you consider the planned use of the section and another reason supporting my original statement that Aluminium trailer design is not for the faint of heart and opens the proverbial pandoras box.
3rd Sep 2018, 06:37 PM #33Most Valued Member
- Aug 2009
- 1,844
Hey Karl, Thanks or the post i need to make one 20 degree bend per each side of the i beam i can cold bend it over 1.2 meters at 16 degrees i than tried to bend that same bend to 19.1 degrees but see the picture below at 19.1 degree's it gets a grainy look on the outside, however 16 degree's is fine there is no markings
pictured is the length of i beam i have been testing with so far to see what i could get from it
4th Sep 2018, 12:23 AM #34Most Valued Member
- Sep 2010
- Lebrina
- 1,916
Is it just an optical illusion or are those two bends at very different radii? It looks like one is a lot tighter than the other. I would have expected 20 degrees to be easily attainable provided the radius was nice and gentle. Having seen your earlier post re bending the I beam in your press, I reckon your method needs some fine tuning. I reckon you need to make a radius former similar to a pipe bender so as to get a gentle and consistent bend radius. Having said that, you may well struggle to bend that way in a workshop press with limited stroke available.
I definitely wouldn't anneal the section as you would then be working with very much an unknown quantity. I have done it for non critical components, but would not be keen for the main runners of a boat trailer.
4th Sep 2018, 12:22 PM #35Most Valued Member
- Aug 2009
- 1,844
2 different radius's Karl it was just a test piece i actually made 3 bends on this piece, first bend was 16 degrees, second bend was on the existing 16 to 19.1 degrees than i tried to use my die on the other radius
I'm going to refine the die i built and use more of a curve instead of the points I'll grind down the welds and run some 5mm flat bar around the radius supporting it where needed and see how i go bending again
i still have another length of i beam that hasn't been bent yet so i will make sure i have a better die before i try it
thanks for helping out Karl and everyone else i really appreciate the advice and help
4th Sep 2018, 07:36 PM #36Most Valued Member
- Aug 2009
- 1,844
Capral sells a few sizes of i beam can someone give advice to best size to use? There is
100mm 6082 T6, https://www.1800aluminium.com.au/cat...sult/?q=998273
101mm 6061 T6, https://www.1800aluminium.com.au/cat...sult/?q=841161
130mm 6082 T6, https://www.1800aluminium.com.au/cat...sult/?q=998274
216mm 6082 T6, https://www.1800aluminium.com.au/cat...sult/?q=808121
Plan Drawers - Canberra
By Blu_Rock in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 28th Jul 2014, 05:14 PM -
Engraving Lines - A Plan
By Anorak Bob in forum METALWORK GENERALReplies: 12Last Post: 28th Aug 2012, 10:06 AM -
Plan B?
By Sawmaster in forum WELDINGReplies: 4Last Post: 22nd Dec 2010, 11:49 AM -
Plan B trailer build
By Franklin in forum TRAILERS & OTHER FABRICATED STUFFReplies: 40Last Post: 7th Sep 2010, 11:03 PM
